paint bubbling on one side
ynot
tiffin
32sa open road
ford
ford
hi
just noticed one side of my rv paint has ripples
no idea why
any suggestions
thanx in advance
Need some additional details. How big are they? Can they be deflected when pressing on them? If so, it sounds like delamination that can occur when water has gotten into the area
I am going with charger man
Find the leak, could be a water line.
Above you can see the water inlet was leaking several times over the 35 year lifespan of my Barth. Better inlets have pressure regulators built in to the inlet.
I installed a new water inlet and put the loop in the hose inlet line so I can change the orings in the water inlet. I can now repair the water inlet from the outside, sliding it out with the loop there. To do this I had to remove the refrigerator. Removing the refirgerator will not be necessary anymore when servicing the water inlet with the loop.
Most common leaks are from the roof.
It’s everywhere on the driver side kind of going diagonally you see it when in the sun
Paint look good when I press my hand on the the paint body looks firm but not smooth
Kinda sounds like the siding is deflecting from some type of settling/deflection of the framing structure. You see that sometimes on the sides of semi trailers
Should I be concerned ?
What is the year, make and model?
Has this just recently occurred or has it been this way for some time.
What make and model
Is the unit?
As Nick mentioned above some pictures would be a big help to clearly understand the issue
I hope this will help
