WilliamW
- Sep 15, 2021
- San Diego County California
- Sunlite
- 16BH
- 17 ft
I am guessing you use the Hughes? thanks for feedback?I have the 50amp version and love it. No real cons that I can think of other than it’s not an auto former, but you know that’s just not what it is. It’s a surge protector.
I love that I can monitor voltages from my phone and if there is an error, I can see that from the phone too and it will send me an alert when something goes wrong.
LOL, as a newbee this was over my head I plan to buy one of these (only) - any CONS for either? THANKS for the help...In my 2019 DSDP, I installed both the Progressive EMS-50HW (hard wire surge) + the Hughes Autoformer 50Amp. This is in addition to the included Surge Protected Transfer switch.
I plan on doing the same installation in my 2022 LADP.
Each component has its purpose
Transfer Switch Surge: Provides surge protection for generator source
Progressive HW50C - Provides surge protection from shore power. Ensures voltage is safe.
Hughes Autoformer - Connected to power reel: Boosts voltage when required.
The power reel output side is a 50AMP receptical that the HAF will plug into directly. I made plug end from the input side of the PI-EMS to the output side of the HAF. WIth this setup, I can easily bypass the HAF if it takes a hit, or if my power reel flakes out, a normal RV cord can be substituted with no effort.
You are looking at 2 different surge protectors --- so you only need 1.LOL, as a newbee this was over my head I plan to buy one of these (only) - any CONS for either? THANKS for the help...
Yes. Hughes Power WatchdogI am guessing you use the Hughes? thanks for feedback?
thank you...You are looking at 2 different surge protectors --- so you only need 1.
The HAF is a strong contender. They both are reputable, both have life time warranty, and are both external. If I had to choose, I would go HAF because of the app on the phone, although I doubt I would ever use it.
@redbaron ... two (2) questionsTransfer Switch Surge: Provides surge protection for generator source
Yes, factory protects both inputs. Due to thenone and done, I chose to protect it with the hardwire version.@redbaron ... two (2) questions
FLSteve
- Does the Transfer Switch Surge that comes with the coach also protect things if on shore power?
- I think I had read somewhere that the factory installed surge protector is a one time trip ... i.e. if it does trip you then need to replace it? Is that sound correct?
