FLSteve
- Nov 18, 2019
- Fort Myers, FL
- New Aire 3547
- 35'
- Freightliner
- 2024 JL Rubicon & 2019 Cherokee Trailhawk
Are you talking diesel?I have never had the push button start feature on a motorhome and was just wondering how it worked. With the key start you have time to let the engine warm up light go out before starting it. How does this work on the push button start?
FLSteve![]()
If you have push button start, then that is the only way to start the vehicle. The Push-to-Start system replaces a traditional key.We have the push button start on ours. I used it once just to see if it worked. Call me old school but I just don't see the point. I have electronic trust issues. Been around it too long and seen too many failures.
This is something that must have been added after the fact. No NEWMAR coach comes from the factory that way. You might want to check the service history on your coach, as this is not right.Actually, there is a start button on the dash and a key switch. You have to have a fob in the driver proximity for it to work.
I just realized the confusion I had with @Dona40 . The coach they own is not a newmar, which I assumed it was since we where discussing a newmar motorhome push to start operation. I guess THOR uses both systems.This is something that must have been added after the fact. No NEWMAR coach comes from the factory that way. You might want to check the service history on your coach, as this is not right.
Other than a "key" that is smaller and less pointy to stab you in the pocket, I don't see much value to push to start. It would be a little bit more secure, but thankfully I live in the woods and don't worry too much about theft.The controls that go Digital provide less “feel”. Analog controls provide much more feel.
For instance the 2017 Vw controls the starter and other functions digitally. Once the battery reaches a certain low voltage the starter refuses to energize. No warning, no indication the battery is getting low. Just stops.
Push button things undoubtedly are run by a Chip of sorts.
Not a fan of loosing that “feel” regarding how things operate.
