Problem Rear air
Dip switches should match your other unit. Use as a reference if needed. Take a pic of the old too as an option.
Getting solar panels on my roof was fun. They do bounce :( I'm not sure how the AC replacement will go when that time comes.
Did you have to get that "special gasket" or did you reuse the prior one? Wasn't there some special shaped gasket required for Newmar?
No special gasket that I saw. The new unit had the thick foam square that seals the duct. That's the only one the original unit had. As far as the dip switches, the new unit has them all off default. I hooked the unit up and the thermostat didn't recognize the second unit, only #1. I had to set the #2 switch on the unit to let the thermostat know it was there.
Now, getting it on the roof was tough. Used a rope attached to the metal base through the box to protect the unit, and I pulled it up the ladder from the top with an assistant pushing from the bottom. It's amazing what can be done when it HAS to be done. 90 deg tomorrow.
I didn't even know they were there till I called NRVR.
I'd suggest everyone check their Penguin II air units. I just installed some Micro-Air soft start today and pulled the cover on my brand new - just replaced unit to find pretty lousy build quality.
It is important to make sure that the air flow is controlled between the low pressure and exhaust zones. Only air should be pulled through the heat exchange fins and not any cracks or tares in the foam or barrier around the low pressure zone.
I found openings in the barrier that should not be there...
Also, the cold cap was not fully seated, and refused to close to be seated and clipped.
This is a brand new unit too, so it's like this from the factory.
My repair was to run aluminum hvac tape across gaps and cracks to seal them. It did make a difference in the cooling of the coach and the A/C vent flow was higher. That means my cold air was being blow out of the gap in the cold zone. There was a gap in the barrier and in the cold zone on both A/C units. Took about 20 feet of hvac tape to seal both units. Not sure if it's the best, but I can cut the tape for maintenance easily if needed.
Not sealing off gaps in the low pressure zone will lead to overheating of the motor bearings and premature failure in the unit.
Thanks for this info. My new unit as well as the old one has the same gaps and leaks. The DW is on the way to the store to pick up some metal tape to seal them up. Also, thanks to @Neal for quizzing me on the "special gasket" that Newmar uses. It uses a foam divider to isolate the supply from the return plenum under the unit. I made the "special" part out of another base gasket that I bought with the unit. Picture below is how the divider runs diagonally. Another tip, when having the evap cover off, pull the 4 phone plugs out of their connectors and spray a little WD in them to clean the connections. If they get corroded, it will throw a code to the thermostat for no communication. While I'm up there, I'll clean the coils on the front unit and I should be good to go for a while anyway (till the next emergency shows up) :rolleyes:
