Replacing bedroom slide motor
lostinfla
Professional nobody
Dutch Star
2021 Willys
After visiting North Trail to get an idea on cost of labor for replacing the bedroom slide motor (I already purchased the motor from Newmar) and hearing "4-6 hours, at $220+ per. On some harder ones, they cut the shaft and install another coupling" (I didn't hear the exact figure as shock set in), I then decided it was something I'd take a swing at. At first glance, I couldn't understand just how it would disconnect as the shaft goes through the gear box and there would have to be a big enough gap between the shaft ends for the box to come out.
After breaking both trans torque bushings loose, I loosened the set screws on the retaining collars at the bearings and to my surprise, the shafts will slide through the gears to the outside of the box to make room for removal, BUT...for some reason, the floor is cut to clear the gearbox, but not far enough to remove it as the box hits the wood before it is able to clear the shaft.
I then broke out the Dremel and cut the floor a little further to clear the box.
At this point I had to also remove the bearing mount to get enough wiggle room to remove the motor.
Finally, the box was able to be removed! I was so pleased, I took a day off.
After that, it was just a matter of reassembly with the new motor and Stage8 fasteners. (didn't install the clips yet in the pic) A word of caution about the torque couplings. When first breaking loose, they will move a bit then tighten up again. You have to beat on the coupler housing and shaft to loosen the pawls in the coupler until the nut will rotate out. Not doing this will break the inserts and require replacement. I actually soaked them with Blaster the day before to make them easier to remove. I cleaned them with brake clean before reassembly. I'm pretty proud it turned out ok and actually works, but more so that I didn't loose a pint of blood doing it.
Nice write up. Flagging this one for the future just in case.
Nice job and glad no blood was drawn. One question is the size of the crowfoot, 1 1/4”?
1 1/2" Here 145 FP torque 1" shaft, (125 FP 3/4" shaft)
Thanks, I should have taken more pics along the line, but I got caught up in getting it done.
leonardo dicaprio bravo GIF
Congrats, nicely done and without loss of blood. Where were you working at, under the bed?
Yes, I found it was much easier after removing the top of the bed base (the piece that folds up with the bed on it.)
Hot damn great job. Unfortunately found a crack on one of my motor posts while recently tightening my bolts the other day. They weren't that loose either and have been tightening them every year. Probably should order a replacement.....
Told neighbor with a 19 DS 4369 about the motors. He never tightened his. Showed him where both are located on the forward slide and the bolts were quite loose. Offered to help him with the bedroom motor and he hasn't asked for help yet.
When i was still employed, I worked with an older guy with more experience than me, and he used to say, "Don't look for trouble and you won't find it". Of course he wasn't working on his own equipment. :rolleyes:
Yeah but I was quite surprised how loose they were. Didn't count but like turns.... Retirement is great isn't it?
Great write up! It appears that besides taxes and the big D we will all have to face the dreaded Newmar slide motor test. Great job on the photos and explanation. Definitely saving this one.
Where are the slide motor control boards located where the "soft set" opening and close settings may be made? Are both (for the forward slide and bedroom slide) located in the same area? Does the bedroom slide motor control board have 5 buttons like the one which controls the forward slide with 2 motors? Thanks in advance for the response/s!
Yesterday I ordered a new bedroom slide motor # K01176M350 (135718 is Newmar's #) from a high rated EBay dealer/supplier for $400 plus taxes and shipping. Lots cheaper than the $808 that Newmar charges.
I just briefly spoke to a Klauber Engineer (producer of the unit) and he confirmed that all K01176M350's will have the brake (as per the Newmar info on their website). I was worried after ordering that my unit may not contain the brake because it wasn't mentioned on the EBay site.
The EBay supplier has 2 units left and figured I'd share this info for potential savings. If interested, Google the model number. I've read that this unit number also drives the front slides on recently produced DS's and likely Ventana's.
We're full timers and can't justify carrying another unit. Mine is supposed to arrive on Monday.
