DennisT
RVF Expert
- Dec 1, 2022
- Superstar 4061
- FCCC
- Cummins 360
- 2022 Jeep Cherokee TrailHawk
- Yes
So, I’ve seen discussions on the new integrated roof drains not actually drawing from the roof.
We have had the coach for a month and a half and the front drains had stopped running through the internal drains. Could see the reflection of the water in the awnings and false awnings.
Called the Superstar number and discussed with the lady on the other end of the phone.
She said to blow them out with air from the bottom.
Since I needed a new compressor for the coach anyhow seemed like a good time to pick one up.
Also picked up a coil of the hard air hose to use for the process.
Access to the duck bills on the Superstar is directly behind the fuel fill doors on both sides and much easier than trying to get to them while laying on the ground . Took the screw out of the duck bill to make room to get the air hose up into the drain portion.
Ran a few feet of the hose up and wrapped the rubber duck bill around the hose to force the air up.
Cut in the air and it actually blew water out the top. Then, when I stopped the air, it started pouring out of the drain as it should.
Did both sides and things are draining normally again.
Thought I’d pass along the what and how as well as the results.
