RV friendly Cummins Recommendation
ARD
Staff member
RVF Moderator
Fulltiming
London Aire 4551
Yukon Denali
Yes
Can anyone recommend an RV friendly Cummins near Mocksville, NC or anywhere heading south towards Savannah? Need them to test my DEF and sensor. Thanks for any help.
Renee
I use boxed DEF too. I had about ½ tank and then was parked in Nashville for 5 nights with temps in 90’s. I don’t know if that has anything to do with anything, but I had no problems when I was in cooler temps.
I added more DEF hoping that would make it better. The warning continued to come on and off. Tomorrow is a travel day so I will see what happens. Meanwhile I have my Def simulator out and ready to go if I need it. Thanks @NWIP.
I am going to try to get into a Cummins Monday as recommended by Spartan, so they can test my DEF and check my sensor. Will let y’all know how it goes. 🥴
Renee
I have used the Cummins shop in Savannah and they do great work. They also changed my DEF head two years ago when I had some intermittent alarms/codes.
Here’s a link to their location:
Best of luck!
Gary
Renee
Two years ago we went to the Cummins repair facility in Albany, GA. It's a small shop, but the service was fantastic...I highly recommend. Garmin will try to give you a false 'bridge weight' warning, but just ignore.
By the time I made it to Magne Shade in Mocksville, NC (getting coach lasered to be fitted with their awesome floor mats), I got a Check Engine light and DEF Sensor Failure. Checking codes, I only have one so far SPN 3364 FMI 11 so should make it to Cummins.
Speaking of Cummins, I called the one in Greensboro and they were dismissive and said they could get to me mid October. I'll be striking them off my list.
The Cummins in Charlotte on the other hand were helpful and friendly. Will head there this afternoon. I've never had my engine serviced, so mind as well do that too and get all the ECM and TCM updates.
Thanks @LeslieGary and @GlampDaddy for recommendations. I decided to go to the closest one instead of taking the chance of heading further south. Will keep those recommendations in my notes though.
@sheridany My DEF was good; my DEF head, not so much. Spartan overnighted a new one and it is being installed as I write this message. Then Cummins will do 6 ECM updates. Then I’ll be on the road again 🎼
Safe, happy travels everyone.
@ARD , how many DEF heads does that make for you? Holy cow.
