Shortest sewer hose?
driftpro
A buddy of mine has a Fleetwood Southwind and I talked him into picking up a macerator.
His sewer out is located inside a compartment bay and points downward at a slight angle. There's a hole in the compartment for connecting things to the sewer out. We cannot connect the macerator directly because of the slight angle of the out pipe, so that means he needs to use a hose.
But his shortest hose is 10' long which is vastly overkill for connecting a macerator (which then pumps via a 3/4" diameter hose). Walmart doesn't carry anything shorter than 10'. Amazon has some about 2' long which is better. Is there anything shorter, like 6 inches or 8 inches? That would be ideal because then the flex sewer hose would set into the compartment hole just barely enough to not drag when not in use... yet be able to snugly connect the macerator.
Any one have a source or clever idea for obtaining a sewer hose just barely long enough to exit the compartment hole? Or is this idea a wild goose chase?
Make one the length you need. I had fittings years ago that screwed into the hose. Use a hose your have and find the fittings you need.
You can buy the 10’ one and easily shorten it to the desired length. Just be sure to confirm that the one you buy has fittings that are removable. I know Rhino hose is
How about adding a clear 90 or 45 to the sewer line and leaving the macerater connected and just run the discharge hose out thru the opening.
This is intended for connecting to the park's pipe, but it could be used for your application. Some PVC fittings to adapt to the end and you'd be done. You asked for a short sewer pipe.
Friends of ours have one that the previous owner added a hard plastic extension on the inside down through the opening.
That made the connection for the hose on the outside of the compartment.
Something like this:
Thanks for the reply. A shorter version of that would work if only his sewer out was straight down instead of being at an angle. With the angle, any hard plastic pipe would have to be the perfect angle (10°? 15°?) and that'll probably be impossible to find.
Thanks. I had originally been thinking about a clear 45° but the angle won't work. It's some strange angle... probably in the teens.
Sounds like one way or another, the solution is: buy a short hose, cut it down to size, and re-attach/attach a fitting.
And probably take some extra measure to make damn sure that fitting is very securely connected to the hose. Like a clamp, or glue, or something.
Thanks, everyone, for your thoughts pointing me in the right direction.
One last thought:
I have now seen that certain 45° elbows are manufactured to be able to swivel on both ends (bayonet fitting and lug fitting) which technically means that such an elbow could be twisted into place for connecting with an external macerator (or another hose) provided you only ever intend to attach to things that will to be left outside the bay on the ground. In theory, that's useful for anyone with such an external-only application and doesn't mind assembling and disassembling extra pieces each time they dump.
However, in our case, I believe he will be far better served by mounting the macerator permanently inside the compartment bay and wire it for power. It'll be much easier to painlessly use this way for the next many years. Since an elbow piece won't work, the solution will have to be customizing a short length of flex hose to fit perfectly from the sewer out to the internally mounted macerator.
I would cut the floor out, some dummy did at the factory in the wrong spot, and fit the pump and then make a new floor out of something to fit the pump.
Time to think outside the box!!!!
Use a 90 degree elbow! This works when the weight of the pump engages the hooks.
I think a 90° would work if we wanted to redirect straight out the side of the rig.
But it won't help with connecting a macerator mounted inside the bay adjacent to the sewer out. For that, we'll need a few inches of flex hose to bend the flow from the angled sewer out into the macerator installed immediately nearby.
Yeah, I bet the factory people very rarely get that stuff aligned just right. It's probably perfect looking on a paper diagram, but by the time humans stuff the tanks and pipes in there, any slight angle throws off the final alignment.
The factor probably figures it's acceptable for the use case of always grabbing a 20' stinky slinky and repeatedly cramming it up into the hole to manually connect every time you camp.
They aren't thinking through how it's not acceptable for those people who want to connect a macerator, although that's probably more of a recentish trend and probably was not as common a couple decades ago.
So if the outlet of the elbow exits aft there is not room for the maserator?? Bummer!!!
