A buddy of mine has a Fleetwood Southwind and I talked him into picking up a macerator.
His sewer out is located inside a compartment bay and points downward at a slight angle. There's a hole in the compartment for connecting things to the sewer out. We cannot connect the macerator directly because of the slight angle of the out pipe, so that means he needs to use a hose.
But his shortest hose is 10' long which is vastly overkill for connecting a macerator (which then pumps via a 3/4" diameter hose). Walmart doesn't carry anything shorter than 10'. Amazon has some about 2' long which is better. Is there anything shorter, like 6 inches or 8 inches? That would be ideal because then the flex sewer hose would set into the compartment hole just barely enough to not drag when not in use... yet be able to snugly connect the macerator.
Any one have a source or clever idea for obtaining a sewer hose just barely long enough to exit the compartment hole? Or is this idea a wild goose chase?
