Boondoggle
- Sep 12, 2022
- Seattle
- Luxe
- 35GRS
- 38'
- GMC 3500 HD
- Diesel
My question is if you think that a single rear wheel truck will be adequate at highway speeds with the occasional high side winds that we inevitably get, or would I be better to order the dually and have to pay for storing my truck? I'm upgrading from a travel trailer to a fifth wheel and buying a new GMC 3500 HD diesel to pull a new Luxe 38' fifth wheel that has a GVWR of 21,000 lbs and a pin weight of 3,700 lbs. (both capacities include an optional 6KW generator on the front which I won't have). In order to fit my new truck into the garage, I need a standard 6 1/2-foot box which is only available with a single rear wheel. The truck with a single rear wheel has a maximum towing weight capacity of 21,300 lbs. and a maximum payload of 4185, so I'm good there. I'll be using a Mor/Ryde pin box with an Anderson hitch, and I've determined that I won't have a problem with cab to camper clearance even at approaching 90-degree angles. I'm interested in hearing your opinion based on your experience. Thanks! Jim
