For those unfamiliar with solar, all the panels on one controller will be brought down to the lowest producing panel. Depending on panel quality, the panel faced out of the sun may even get hot enough to discolor over time.For storage purposes with our travel trailer, I use two out of the four panels plus the charge controller from a roughly $150.00 Harbor Freight 100 watt solar panel kit. I aim one of these panels towards the morning sun and the other towards the late day sun. With a healthy battery, I could still pump water, run the lighting and the propane leak detector is on - I can't turn that off.
And if I chose to, I could run the refrigerator on propane in conjunction with 12 volt support from the solar-charged battery but I usually don't.
Works great.
Rick
