redbaron
Moderator
- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
I did receive information. Here is the quoted text from the email:
I now need to compare this.
The 1000 pound 70% extension in our steel slides would be model SM2-SP with a profile height of 2 7/8 inches high. The tray would sit on top of this. we offer 1/8 or 3/16 inch thick Aluminum with 2 inch lips turned up on all four sides. So with a 1/8 inch tray, your total amount of height would be 3 inches.
On our Aluminum frames, the model M2 would also have a height of 2 7/8 with the side rails being a total of 5 1/2 inches. With this model, your tray lays down inside the side rails, and a 1/8 inch thick tray would again give you a total height of 3 inches.
We have a standard turn lock on the slide which needs to be held up 1/4 turn while the slide is being operated into its outward position. There is an upgrade, the IMS spring lock, which you unlock, it does not require you to hold it while it is opening and locking into place. With this IMS slide, you are able to guide the slide to its open position with both hands.
