2cmprs
- Sep 5, 2020
- Chesapeake Virginia
- Grand Design
- Transcend Explor 221RB
With the chrome cast, I believe you just use your phone as a wi fi hotspot but I'm not 100% on that.Is there a way to stream from cellphone to a standard LED LCD HDTV (no smart TV)?
I tried Chrome cast but it requires a Wi-Fi SOURCE.
I don’t think you can airplay to an AppleTV directly without a LAN. I could be wrong thoughIf you're using an iPhone you may be able to use AirPlay to an Apple TV attached to your TV via HDMI.
Amazon.com
www.amazon.com
I think you're right but with an iPhone and a plan that supports tethering, the phone can be the WiFi. Better have it plugged in, battery drain will be a problem.I don’t think you can airplay to an AppleTV directly without a LAN. I could be wrong though
I tried Chrome cast using my phone as a hot spot but it wouldn't work.Without WiFi, you’re almost certainly out of luck. Even AirPlay requires both devices be on the same WiFi network.
TBH, just go get a dirt cheap WiFi router if you need to. I am sure you can find a used one very cheap. It doesn’t need to by anything special and you don’t need internet to make this work. You just need to create a wireless network with the device, which will in turn create a Local Area Network and allow the two devices - your phone and TV - to communicate with each other. If your TV is not a “SmartTV” (note: most of not all SmartTVs are ridiculously dumb but hey, marketing!) you’ll need something like a Chromecast to bring those capabilities to your TV.
What is DTV?Anytime I’ve done this I have been on WiFi and used a lightning to HDMI connector. If no WiFi if you have cell service you can use your phone as a hot spot. I use DTV and stream from a phone or tablet. There is no data charge for this with my provider.
Don’t have either so I can’t say one way or the other. Again, I think your fastest and easiest way to just buy a cheap WiFi router and plug it in. Then connect your TV to that WiFi network, and your Phone to that WiFi network. This will allow your phone to communicate with your TV.I tried Chrome cast using my phone as a hot spot but it wouldn't work.
Today someone told me that they use a fire stick in the same way and it works great!
Pretty sure they are pretty much the same thing.
