B&T RVers
- Nov 4, 2020
- Vero Beach, FL
- Ventana 4037
- 40"
- 2018 Jeep Wrangler Sahara
That's what I have. The well water at the resort in Florida is almost orange so filters and softener are needed. I think I did regen on it about once per month this winter.There are areas of the US where you'll need it such as the AZ area, UT, I've even had on the eastern shores of VA. You don't want hard water in your RV so I would nearly say a water softener is required to have in hard water areas. You can use test strips that come with it, or buy separately, to test your water. This is what I'm doing in higher risk areas to see if I need to setup the water softener. Some stated it's heavy, you can mitigate most of that by emptying the water out when stowing. Here is what I use. The bigger one means less time between regens, in AZ for one person with the larger unit regen is weekly using salt.
On The Go OTG4-VM-DBLSOFT Portable Compact Double Standard 16, 000 Grain Water Softener w/Brass Fittings, Back-Flush Adapter for RV/Marine Models - - Amazon.com
On The Go OTG4-VM-DBLSOFT Portable Compact Double Standard 16, 000 Grain Water Softener w/Brass Fittings, Back-Flush Adapter for RV/Marine Models - - Amazon.comwww.amazon.com
That's true. We used to have to wipe the glass after every shower.I also use an On the Go softener and wouldn't think of not having it. If nothing else I don't have hard water spots on the shower glass and the fixtures.
I too have the water softener installed in a different bay. Also have valves too isolate it while it is removed for regen.I did a permanent installation in a bin, plumbed in with bypass valves so it's in use all the time. I typically do a regen once a month. I made a regen adapter out of a filter housing that I fill with salt and attach to the in line to avoid removing the unit from the coach. Has worked great for the past 2 years or so. Don't think I'd ever go back to hard water.
I made it from a filter housing (holds just shy of 2 salt containers). Connects in line with quick connects on the valve I installed to transfer the salt to the tank. Works great without wrestling with the tank.I too have the water softener installed in a different bay. Also have valves too isolate it while it is removed for regen.
Sounds like you have a better idea. Could you explain your regen adapter a little more? A picture would help me.
Thanks
Let's see itFinally got around to the permanent install, thanks to lostinfla.
Pouring the salt in the extra filter housing makes it so much easier.
Thanks.
