Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
You seem to be very knowledgeable about plastic pipe, but what does this have to do with helping people solve solutions to their problems?Here is some interesting information Plastic Pipes - Maximum Operating Temperatures
The assumption is that this is thermostat delivered with vehicle. no doubt heat appears to an issue. The question then becomes why was the hot water circuit designed with this material? If they knew that hot water would cause leaks?
Don't care. As long as problem gets solved.The assumption is that this is thermostat delivered with vehicle. no doubt heat appears to an issue. The question then becomes why was the hot water circuit designed with this material? If they knew that hot water would cause leaks?
