Resolved Water pump shuts itself off - frequently! (Newmar)
10-4 - Thanks!
I have a 2007 Newmar Coach also , I have 3 switches 1 by the sink 1 in the wet bay and 1 in the bathroom . How do I turn the water pump off ? Another question I live in Canada beginning to winterize my unit. How and where is the shut off by pass switch for the water heater ? I have drained all the fresh water and the next step is to add the plumber anti freeze. Thanks
If you have a typical propane water heater, look for a valve in the plumbing directly in front of the water heater, probably in the back of a cabinet. Wherever your water heater is placed, the by-pass is probably not far away.
As far as shutting off your water pump, it should be off and stay off if any one of the switches is turned off. Not sure I understand the question.
As far as my system goes, the controller seems to have been the problem; the new one has been in service for over two weeks and the system has stayed on, so I’d say the operation was a success.
Thanks for reply ! By turning off those 3 switches 1 in the coach by kitchen sink and 1 in bathroom and also 1 in the outside bay , will that turn my pump off ?
any one of them will do it. Do they have an LED as an indicator that the system is on? Mine are spring loaded, momentary switches, so if I turn one off, hitting another would turn the system back on. Your’s must be regular switches.
