You should not have to do anything to the winegard from the top of the camper. There are winegard switches inside. Pictures of the equipment and output you have would help.Yes it has jacks out label Cable/ Satellite. I have found no switches inside only the 2 jacks by the Tv and I’ve tried both. Is there anything on top of camper by the Winegard antenna I need to switch I looked and found nothing on the outside of it.?
You are so helpful and reliable.From the Crossroads owners manual”
“How do I hook up an outside satellite antenna?
If your unit is equipped with an external satellite jack, hook the satellite antenna to the jack and hook the satellite receiver to the connection provided inside.
If your unit is not equipped with a satellite connection, run a cable directly from your satellite dish to the receiver. The cable hook-up that is provided with some units will not carry the satellite signal.“
Apparently, there is a separate “satellite” connection inside the RV that mates with the one outside. Connect the sat receiver to that one and the TV to the sat receiver. And, be sure your TV input is set to “Satellite.”
If that doesn’t help, I suggest that you call the Crossroads customer service folks at (866) 425-4369 And have them talk you through the process. Good luck.
I am having same problem….my outside hookup is only satellite. The only switch I am aware of is the booster antenna switch… I’ve tried that on and off. No powerWhy is my Satellite not working coming into my TV it has a Satellite port outside but won’t get power to my Satellite outside hook it up directly and it works??
