What extras do you bring for your trip?
Yorick1973
Idaho
Grand Design
Solitude 378MBS
42'
Lord willing, we start our RV full-timing in a few months. See this link for our intro.
I've read up on many topics to prepare. One topic I can't find is this: Carrying Extras. For your RV trips, what do you carry extra of? For example, Do you bring an extra sewer hose in case yours rips during use or setup? An old hose can easily tear as it becomes brittle and weak. What about an extra water hose?
Space is precious in the RV especially with 4 of us traveling. So, I don't want to use up space unnecessarily. However, I also don't want to be too strict on what I bring.
So, what do you guys bring a spare for?
Welcome from Ely, Iowa. We carry fuses, hose clamps, light bulbs and fairly complete set of tools. On a long trip we carry a spare tire for the coach in the bed of the toad. Many times on short trip <100 miles we do not pull the toad.
Been doing this for about 15 months. Different park at least twice monthly. We carry 3 sewer hoses and 4 different size fresh water hoses. We have actually needed to use all 3 sewer and two longest drinking hoses at some sites. My water bay and the sewer connection are middle unit.
Common is for 2 sewer hoses and one fresh. Have actually needed to use a power cord extension in 1 or 2 parks.
For me I use a lot of plastic tubs. Keep fresh and sewer items separate and hand vs power tools separate. When (frequently) I need to do some adjustments or repairs I can just grab a tub and I have what I need. Even have small containers in larger tubs for parts etc.
I am a bit compulsive but I hate to look for things when working. Repair time, setup time and break down time just delay my camping time. Works for me.
Oh yea. I forgot the park we are at has only 30amp power. We are 50amp. Be sure you have a power converter.
We also carry a spare power cord and a multi port hose adapter. This allows us to hook up to water and still have access to the water faucet if needed.
A spare hitch safety pin is good to have. On my second trip (I've only done three so far) I unhitched and because the rear bumper of the truck is a nice shelf I put the hitch pin there..... and forgot about it. Later that night I went out for dinner. By Sunday (me... looks around...) no hitch pin!! Ugh!! Thankfully I was camping with my brother and he had a big cotter pin that did the job getting home. But having a spare (or 2) helps!
Speaking of cotter pins - If you use cotter pins on your weight distribution hitch, a few extras would help there too.
As mentioned above - Fuses - for the tow vehicle and trailer. Always good to have extras of those.
Water hose washers. A few extra fits easily in your tool bag/box.
Keys/FOBs! to your rig and/or truck.
Some folks bring an extra water filter. Sometimes they go Kaput during a camping trip.
I'm still learning myself and am constantly making notes.
I offer up an exercise!!! To start I explain. To fultime implies live!!!
In a stick and brick, as you need something to complete a task, it's a run to the store, and the next time not!
The RV life is different.
Space is different!
So now on to the exercise!!!
Pack you kitchen, bathroom, and living room items, and store them in your extra rooms! You're moving right?
Don't seal the boxes! You will be digging in them before your finished.
Keep out the nessisary items. You know, bowls plates silver, pot and pan (as few as you can) dinette and chairs, sofa. The nessisary items including bed.
Live in those rooms!!!
Every time you need an item, before you retrieve it, ask yourself if you already have something out you can use in place of it. If not consider if you can do without!!! If you need it, dig it out and put it in your take pile.
Note:
You can't take much of what you have in an RV, just to many limitations. You will do this exercise sooner or later, so now will make it easier!!!
If you were provisioning a boat to cruise, spare parts are a big thing, but, you can find what you need to make it work in almost any town you travel through.
Getting yourself conditioned for the journey is more important than spare parts! You are downsizing not the other way around. When at the start date of your journey you may still be wondering where you will put the stuff in your take pile, and need to do some more reducing, those that do the best at this have less pain adjusting than rest!
Good luck!!!
P.S.
Those things your on the fence about, they make storage lockers for!!!
I could recommend extra hoses, or for that matter a table saw!!! But I won't. Conditioning yourself for the journey is most important!!!
Probably not a complete list, but:
  • Spare fuses, electrical tape, duct tape, bulbs for bay lights
  • Cummins: Spare fuel and water Seperator filters, power steering fluid. Serpentine belt and AC compressor belt.
  • Oasis: Spare filter and service kit for Oasis. Spare Oasis pump. Boiler fluid.
  • Spare water pump and negative block (can't remember what the block that the negative hooks to is called)
  • Leveling blocks, spare water hose, four sewer hoses in assorted lengths and extra caps and screw in dump adapter.
  • Drill, socket set, wrench set, assorted other tools/driver bits, multi-meter
  • Compressor, a couple air pressure gauges (including one that can hook to air blowoff governor)
  • extra pins for tow bar (toad end and coach/receiver end). Extra breakaway brake cable and pin/key to go in brake breakaway unit on toad.
  • Spare tow bar (my old one, I threw in a bay.
  • Extend a ladder, and folding A frame ladder
  • Starlink and external cell antenna, either of which can be mounted on flag pole buddy setup.
  • Those are probably the biggies, but I'm sure I'm forgetting a fair number of small things (like spray lubricant, etc.,) of things in my bays.
Not compulsive to me!
I bring a lot of stuff (including nearly everything @Tnedator listed) - spare filters for everything, lots of tools, spare parts and supplies as they accumulate or occur to me, also stuff I read about here. And I don’t even full-time!
But I also jettison stuff that I haven't used in a year or so unless its typical spares that I might need some day. My limit is space, not weight as I have nearly 5k lbs NCCC but only 35’ of coach, so I’m always looking at bulky stuff to leave home.
I do have an extra 35’ of 50amp cable (total 70’), and extra water hose in case hook-ups are too far away. I also have a bin for my sewer hose so I carry an extra length and occasionally use it to extend.
Indoor storage (more organized than it looks): bins for radios, flashlights, supplies, indoor parts, remotes, chargers and cables, indoor tools, and misc
Tools, chargers, kits, etc
Outside storage for small parts, maint items, supplies, etc
Serwer hose bin - very handy, holds a lot of hose, and keeps it out of the wet bay.
Thats the bulk of it other than chairs, BBQ, mats, and all the typical camping stuff. Overflow ends up in the back of the jeep.
Don't sweat it. You will add and toss many things over time.
A small basic tool kit, gorilla tape, replacement bulbs for exterior running lights.
Hose washers, not the cheap vinyl ones. These are good and 100 lasts me a loooong time Amazon product ASIN B0B8V3L1J7
Water hoses are best in 25 ft lengths. You can always connect two or more together. I like to buy a 100 ft hose and use hose menders to make several shorter hoses. I use quick connects to put them together. I try of have one 10 to 15 ft hose.
Two 10 ft sewer hoses are better than one 20 ft sewer hose. You can always connect two or more together.
Water filters (I prefer the "whole house" style in the 10" canisters)
There is a Walmart in almost every town in the US. It's amazing what you can buy at a Walmart.
You need a little electrical outlet tester and know how to use it. A cheapie from Harbor Freight will let you know if an outlet is mis-wired. And if you lose it, it's not expensive to replace. You will need an adapter just to plug the tester into for the 30 amp outlet and the 50 amp outlet. You want to test before you plug your RV in. Electrical Receptacle Tester with GFCI Diagnosis
Know how to test an outlet. Here's two sites.
You need an electrical adapter, depending on what your RV is rated for. A 50 amp RV needs to be able to plug into a 30 amp outlet. A 30 amp RV needs to be able to plug into a 50 amp outlet.
You need a cheapie garden hose splitter or "wye" along with a cheapie pressure regulator to use on the sites hose pipe (you will eventually leave it behind) . Save the expensive ones for a permanent connection on your RV. The cheapie is just to save your water hose.
You need a sewer collar. You often get them with a sewer hose kit.
Some parks/campgrounds do not allow sewer hoses to lay on the ground. You may want to pick up a sewer hose support.
If you have a decently sized fresh tank, you do not need to hook up to the potable water every night when traveling. You also do not need to dump your waste tanks every night either.
All the tools that have been listed in previous posts.... would you know what to do with them?
As LMHS says, you can easily pick up stuff along the way as needed (auto parts and hardware stores, Walmart, etc) and many RV parks have the basics at not too inflated prices, so you’ll rarely come up short. The water pressure regulator is a good point - some parks have water pressure high enough to damage your fixtures. Part of the fun (for me) is going on a scavenger hunt for some unforeseen need. In Memphis I needed to test AC capacitors and my multi-meter didn’t have that feature. So off to Lowes and now I have a better compliment of testing stuff.
I carry a lot of stuff but as I said, I have a lot of capacity for a small coach and as a result I rarely need something I dont have, and I often have exactly what a neighbor or other camper needs in a pinch. I also plan small easy projects to do when I’m on the road for those days when I have nothing planned and feel like tinkering so that stuff gets thrown into my inventory.
generator
There are many airlines on my rig. My BaRTH has air brakes, air throttle, air shifter, air wipers, and air suspension. The air dryer filter was replaced after 10 years of me owning the BaRTH. When I purchased the BaRTH, I installed a separate air filter system for the air compressor. The compressor was using filtered air from the main air filter off the engine. With the separate air filter is not competing for air with the 10.4 liter Caterpillar.
I decided to have a few backups on board. We all carry some spares. We never have enough. I assembled a little air repair kit with the help of Commercial Truck And Trailer, in Girard, Ohio.
Here it is.
It consists of ½, 3/8, and ¼ airline hose and some push lock connectors. We also included some right angle fittings. The straight push lock fittings should get me out of most air leak problems with ten foot of each size hose.
I really hope I never have to use the kit. If you have any air systems on your rig, you may want to assemble a kit for your peace of mind.
Self fusing silicone tape can eliminate the need for carrying a spare water and sewer hose depending on where you are going. It may not last forever, but I have used it for a temporary repair until I can get it done correctly. This may help offset some bulk storage capacity until you can get replacement parts from other sources.
