Administrator
- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
The A-10 error code is typically an easy fix, remove the lower right drain plug. For those with shedding dogs such as my daily shedder, you will become familiar with this error code. While I flew A-10's in the Air Force I don't appreciate the nostalgia my whirlpool washer provides me far too often. In recent uses I cannot get past this A-10 code. I've tried everything from the drain plug, power off, you name it. Next steps in troubleshooting is either a clog somewhere or the drain pump is defective.
Today was my day to rest, relax, enjoy a peaceful campground. NOPE, today was a day from hell. Doing this yourself is difficult and it's a lot of work but the moral of this story is many have a problem and just replace the unit. All compact washers are highly prone to problems, they are not reliable, so either throw thousands at it or learn to fix it. Today I did a lot of google research and came across great discussions, great guides, and tech videos. I removed the cabinet doors and all hinges, unscrewed the toilet from the floor and slid it against the wall as I learned to do when Newmar had a RV mobile tech come to remove this for a Whirlpool tech to do the typical door lock replacement (wrong fix for that issue) and replace boards. I then removed the dryer which wasn't nearly as bad as trying to get it back in.
Long story longer I disconnected the hoses to and from the drain pump and nothing was clogged, no signs of any problems. I had some trouble getting the hose back to the drum secure but eventually got it and reassembled everything and surprisingly didn't have any screws left over. Prior to stacking the dryer I ran a test cycle (normal) with a towel which failed this morning, after reassembling it worked fine. High speed spin, no A-10 errors codes, I could hear the drain pump pushing the water out, all checked good. I had a difficult time stacking the dryer myself getting the dryer hose and plug all where it needed to be so I busted the control knob off the washer, hopefully I can find a replacement, fortunately the break seems to be within the knob itself and not the washer side. Oh well, I did mark the off position with a marker so I can still use it. I did two loads of test laundry, both sets of towels and it worked perfectly.
I uploaded the guide I found to the resources area:
rvforums.com
Here is a web site which I think is for tech training that has videos for just about everything. A little challenging to find some topics but they are there.
video.whirlpoolcorpsalesacademy.com
Off to find a replacement knob. If the price is right I may pickup a drain pump as it may be on its way out. I hope to never remove this washer and dryer again but now I know how should I need to.
NOT FUN!
Whirlpool 24 inch Compact Washer Tech Manual
Reference for Compact Whirlpool Front Load Washer
Remove Top Panel - LEARN Whirlpool Video Center
NOT FUN!
