- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
Same, I've never used spigot to flush, I also spray with bleach solution like @jaydee325I always make sure my gray tank is pretty full and use it to rinse after dumping black water.
Dump station water spigots are used for everything imaginable, and some unimaginable. Often in rapid succession.
CG water spigots have the luxury of a two-hour or so gap between check out and check in. That two hours affords the spigots the ability to forget how they were used. Therefore, clean slate.
What is the distance from the dump port and your spigot at your campsite? Is there code that mandates this distance?it’s the proximity of the hose to all the nasty stuff being dumped
