Wimpy AC units?
Steve and Cindy
It’s pretty hot here and our AC units can’t keep up. They seem to be blowing cool air but it’s still hot in the coach. AC has been on all day. This winter we’re going to Florida. I’m sure we’ll need the AC to keep up. Just wondering if any of you have ACs that don’t keep up or do we just have an issue with our rooftop ACs. They keep up just fine if it’s not that hot outside.
Also, is there any way to run both at the same time?
2000 London Aire.
I think most coaches, okay, well, mine, you have to stay ahead of the heat. Once you have heat it's hard to cool it back down. This means shades down, maybe insulation pads in the fantastic fan vents, magneshades to keep heat on the outside of the glass, the list goes on and I posted a thread here long ago about keeping cool tips. Cool down early and stay cool as again, once you're behind you won't catch up. With that, I've had good success.
I run all 3 of mine at the same time, if you're on 50 amp running both is no problem.
In addition to Neal's list, have you kept up with AC maintenance - cleaning the evaporator and condenser coils. Cleaning the filters. Also, if (big if) those units are original, they are probably getting old and tired.
Back in the good old days, you know, when people knew what is a book? The answer to cooling was shade! I didn't say no ac just that shade reduces wall temperature thus the need for BTUs. The books gave the numbers, sure that is done digitally now! But I knew the book in my book shelf that had that information. Now it is just memory, so I lack the gains.
Are you using your awning?
To all responding, did you see where the OP is only running one AC unit at a time?
Of course we did! I only run one at a time, and the awning is out, and the solar panels shade a good part of the roof.
2000 London Aire.
If you're connected to 50A you should be able to run both. Does yours not allow this?
I always run both AC's. I run the one where I am not sitting 2 degrees or so, lower so as to minimize blowing cold air on me as intensely. When I had a 30 ft class C with only one AC, it was difficult to cool the coach on a 95 degree day.
You can only expect a 20°-30° difference between outside and inside temp - for an older unit, probably closer to 20°. So the more you do to help (all the pointers previously offered), the better. Also as I think Neal pointed out, these units don’t recover well, so start early, get it cool before its hot, and then keep it that way.
