Micro-air Easystart/Bluetooth
J&JD
Fremont, California
Dutch Star 4018
40’
Cummins ISL450
Jeep Wrangler Sahara
I’m considering purchasing a couple of the Micro-Air units for my DS. My question is is it worth it to get the Bluetooth version? Doesn’t seem like a huge advantage to me even though there’s only about a $35 difference in price.
I just purchased 3, and decided against BT as I don't know that I need the data Might miss it, but I doubt it.
I didn’t know there was a non-BT model. That being said, I love the device. I think the BT function is helpful as it allows me to control the thermostat if my router is off.
I assume you have the micro air thermostat? I was referring to the easy start which I assume @J&JD was referring to.
DOH! Sorry guys.
I do have two micro air soft starts as well, but without Bluetooth. I wish it did….
DOH! Sorry guys.
I can't figure out what I would gain with BT... what do you see as useful?
It's an install and forget. No BT.
Ha. So I admit I never looked into it after I bought mine in early 2019…when the Bluetooth option was not available. I looked back now and was unable to determine what data you can ascertain from the device via bluetooth….so without that info, I will also have to say I am not sure its worth it. I tend to be a data junkie, so I normally would opt for the Bluetooth…
They do a poor job of selling the upgrade. We have 3 people willing to pay more if only we had a justification
It would be nice if someone could outline the install including pictures here at some point. @Chuggs did so for me and made my 2nd install super easy as I paid for someone to do the 1st install who did a poor job. Wish I could find the info, it's a very easy install if you have good directions.
I will in February 2022 if no one beats me to it
RedBaron, I have inquired to MicroAir who states they do not support an API for integration...I am surprised you purchased these because of that....is your thought you will reverse engineer the MicroAir to integrate it in your new rig (cool)?
For mine, I will be developing dumb relays MQTT to a smart control system to replace all climate controls. No UI at the thermistor. Parts should be arriving today to start the project.
re: MQTT - we should share the MQTT / JSON so that only one software driver is needed to interact with both approaches....
re: bluetooth - no need for that in my architecture. Just a webpage to control not just the thermostats, but everything in the RV. So all current smartphones / tablets / on wall browsers will be usable.
I didn't buy BT. No need. I just want the soft start.
Do you need the MicroAir thermostat to add their softstart circuitry? I assumed the softstart can be used with any thermostat? ie: call for Cool, triggers the softstart circuit that then fires up the compressor....
I haven't done too much research like I know you have on softstart....If you have a link to that thread / discussion / tech, please send.
The Micro-Air soft start has no dependency on or connection to a thermostat. It is a capacitor replacement.
I ordered two of the Micro-Air EasyStart 364 Bluetooth models from TechnoRV.com and installed them on my 2023 Newmar New Aire 3543 today. Installation on the two Dometic Penguin IIs went flawlessly as the step by step instructions (with photos) and the bits included in the optional Installation kits made it easy peasy. After going through the 5 learn procedures on each they were both set up.
The Bluetooth is awsome as I could monitor the learning procedure without having to climb up and down my ladder to watch LED indicator lights do their thing. That alone is worth the Bluetooth version for me!
Best,
-Mark
Best,
-Mark
Can you outline the install? How technically savvy do you need to be? I just had mine opened up to clean the condenser and evaporator coils, but that's the only HVAC work I've done. Do you install the easy start in the area where I was with the condenser/evaporator coils, or from below?
Also, I see lots of people talk about having soft starts, but what is the practical benefit of it?
The install instructions are available from the Micro-Air website. This is the PDF I used since I had Dometic Penguin IIs. You'll see that it is pretty straight forward. Redirect Notice
That said, if you are not comfortable working safely on 120V circuits I'd recommend paying an RV tech to do it
Best,
-Mark
