Yet another tire blowout
Should know some more tomorrow as the shop plans on getting it on a lift, and adjuster will be there but here is what I have been able to research so far. None of the videos/pics of installs of Tyron (or retro band for that matter) show the kind of tire damage or the jackhammering in the steering wheel I experienced. This leads me to think the culprit may be the tire. I was able to verify though the Tyron band had slipped out of position, so it's possible it contributed to the damage/loss of control, and was possibly not installed correctly in the first place. What was left of the tire stayed on the rim so that part may have worked but I had zero sidewall still attached to tread to drive on so no control ability as the videos of both products demonstrate. I will post what I find out. Am still shaking a little after seeing the post of the semi/RV collision on the 81 and how close we came to duplicating that.
Thanks for the update. I’m going to work on armoring the rear surface (facing the front left tire) of the drivers side front (electrical) bay this week. Given the steel framing that is already there it should be fairly simple and effective. I’ll provide more info as that effort progresses. It seems fairly clear that losing all chassis electrical contributed significantly to you inability to control the coach.
I am so glad to hear @Scotttkd2 is okay. My comfort drive went out on me and it was so hard to steer. I don't know how you did it with a blowout. Excellent driving and trusting yourself when it was time to brake.
I have to say, I've been thinking about putting the run flats on my front tires when I go to Spartan in November. The semi and RV accident really shook me up as well. BUT, there is always a but and a what if .... they don't install them correctly. Keep us updated and keep well. Be especially kind to yourself. You've been through something very frightening.
@Joe Hogan , not to say I’ve seen them all, but the pics I have seen of blowouts with Rettrobands the tire stays intact.
Agreed, I don't think there have been a lot of blowouts yet, but I think I've seen two posted on forums, and both had zero damage beyond the tire, from what I can remember.
Tyron and Rettroband take two very different approaches. Tyron has a little rim installed inside the wheel, and "if" your tire stays mostly intact, it's supposed to help keep it from sliding all the way to one side of the wheel, therebye delaying the tire coming comletely off.
Rettro is basically a hard rubber wheel inside the tire, which sits higher than the rim of the wheel, so when you have a blowout you drop down on to the rettroband, which still keeps the rim off the road.
Still very little real world examples of Rettro blowouts from what I've seen. I bought them, because right now they seem like the best option out there, but time will tell how well they prove out in the field.
Yup, not a good day 1 of most recent trip. Currently sitting in Albuquerque NM with RV at a Freightliner shop for the foreseeable future. Driver side steer wheel shredded and took out the electrical bay. No power steering, no dash, no slide controls, no levelers, cant start engine. Wound up partially in the median of I40 with patio side outside dually off the ground. Luckily we didn't roll it, and I had just swapped out the blue ox tow bar that bound up if not perfectly flat for the NSA ready brute that had enough rotational give in the attachment points to release the toad Even at the angle we came to rest at. Recovery tow dude was a miracle worker and managed to get hooked up and drove it into the bottom of the median without rolling rv and himself and was able to get it out. Once Freightliner finishes its repairs it will need to go to a body shop for their work, so we are grounded for a while. Luckily no injuries and didn't cause any accidents as it went from the right lane all the way to the median. TPMS was active, no warnings, and all tire readings were in specs and consistent across the board with the usual running temps and PSI. 19k miles on this one, the front right tire looks perfectly normal and healthy. Scratching my head on why this one would have blown, rear blowouts a year ago were related to Freightliner valve stem recall and I can understand why they went.
OK Scott, you get credit for the inspriation and identification of the problem. Thank you for posting the story, pics, and all the info. I armored the front of the wheel well and since I needed to brace the frame I built for it anyway, I added protection for the bottom of the bay to prevent damage from road hazards. This is 14ga steel so I think it will do the job. It took me around 8 hours over several days because its been hot and I had covid the whole time which didn’t help but this gave me something to do. If I had a real shop and a ready-to-build design, it would take around four hours to do this job. Materials were around $100.
What I had to work with: HWH added a lot of stuff when they installed Active Air and their framing here prevented things from being square and level, but I went with what was there.
My additional framing
The new wheel well piece and the underside protection - 14ga steel, 1 1/2”x 1/8” angle.
Final product. It’s not as clean as I would have liked and I had to give up on square and level, but its done and it will do the job. It also protects the Active Air stuff better.
View from the front with road-hazard protection/bracing in place.
The wheel well piece is 31”x20”. If I were doing it again I’d make my life easier and cut it down to 30.5”x 18”, my hindsight being pretty good. But by the time I figured it out I had Covid and I dont have a power sheer at home, so I went with 31x20.
Also I only welded stuff that wasn’t attached to the coach because I didn’t want to disconnect everything, and I also want it all removable, although I hope I’ll never have to do that. It would get beat up if I had a blow-out but it’s fairly stout and it would protect the nerve center so that works for me.
After Scott‘s experience and that story @Jim posted about the head-on in PA a few days ago (don’t know the details but it was compelling), I decided this is a necessity and perhpas the issue is worth a visit to the NHTSA website. Losing a front tire is bad enough; losing steering too is not an acceptable risk. Before Scott’s original post on this, it never occurred to me that the essential electronics were so vulnerable.
Nice job! I was hoping to have an update but both adjuster and shop are waiting for phone calls back on part numbers and availability for some of the electronics. I got a quote on the chassis side of the repairs and they are replacing the front wheel and tire obviously all other chassis suspension components appear to be ok. The fact they even have it in the shop already was encouraging but I still need to get the body shop involved so right now it's still hurry up and wait! Sure wish now we hadn't Airbnb'd our Prescott Valley home, as we are sitting in another airbnb up the road until ours frees up next month. Murphy's law and all that.
This is what that bay should look like and I’d like to keep it that way. Scott maybe you’ll find this usefull as you get your rig put back together.
Hey Scott, I’m looking at other areas in wheel wells to “tire proof” including the top of the drivers side front. Did you get any damage there? Looks like an easy one to improve so I’ll probably do it.
Here’s a shot of the finshed product with a little better perspective:
When I had the idea it was in the aftermath of my rear tire blowout, (that thread is here somewhere with some pics of the damage) that took out my "tool" bay, nearly put a hole in my fresh tank, and destroyed the thin aluminum bay/box behind the tire. It got me thinking if the driver side (which was ready to blow out the valve stem extension within a few hundred more miles ) would have done the same thing I was looking at my def bay (not a good thing to get damaged) and on the other side my entire plumbing bay (also one I wouldn't want to try getting along without. Thus was born the idea to armor up the wheel wells. I saw they had the 1 inch square tubing all around, so I found heavy duty wire reinforced mud flaps on amazon bought them and had the repair shop cut to fit and install on the square tubing. I still believe it is better than nothing and would give the shredding rubber something to beat on besides the light gauge aluminum and the cheap particle board they used to construct these things with while I am getting the RV to the side of the road and stopped. Unfortunately it didn't occur to me to have the fronts done, as I had the Tyron installed which was supposed to prevent the issue. Live and learn. I am already ordering more and have my repair guy standing by to fit them up on the fronts if I cant get the shop to do it. Glad to hear my experience has prompted someone to be pro active and hopefully avoid a disaster of their own. That's what these forums are for in my opinion. BTW I can hardly watch the video of the I81 wreck in the median. By the grace of God and my guardian angel working overtime on a Sunday that wasn't me and my wife.
Sorry, I missed your question, for some reason the top did not sustain any damage in either blowout. On the rear the top pealed back the rubber membrane, but did no damage to the wood/steel underneath that.
Ok thanks. I’ll do the tops of the wheel wells in 16ga - lighter, cheaper, easier to work with and since that surface is farther away it should be fine. There’s also very good support there so it will be a simple task.
I’m going to continue with the project until they are all done, but none of it will be as heavy duty as the protection for the electrical bay. That was probably excessive but at least I know its safe. Also my local welding supply shop will make all the cuts I want at no charge on their power sheer, so I’ll design the next phase in advance and get the material cut to fit when I pick it up. With all the steel in the “Star Foundation” it should all be fairly straight forward. The elec. bay project was complicated by the HWH stuff— the others don’t have any obstructions.
Update - Freightliner repairs are underway, was surprised how inexpensive the electrical components were. Two PDM devices and one wire harness so far identified as needing replacement, under $600 in parts for that. Replacing the front wheel and all 6 tires will be replaced on the chassis side, (my choice, out of an abundance of caution and the fact that we are now down 3 of the six original tires), then off to body shop for another round of estimates. ETC for chassis/electrical is 9/6 so not bad considering, but no idea yet on the bodywork as no estimates have been completed.
At this point still no idea what happened to the steer tire, there is no tread anywhere on the remains just torn out and frayed belts. Both sidewalls are intact and remained on the rim, I suppose due to the Tyron device holding them in place. I have found no blowout pics or videos that duplicate the look of the tire online anywhere as of this time. Am leaning on replacing the Tyron with the Retrobands but not decided yet. Will be hardening/armoring the electrical bay like I did with the rear tire wheel wells later this fall after we get back to Florida. 20/20 hindsight but all I can do now.
Scott, I read what you wrote on the other thread about gouges in the wheel from the Tyron install. I'm surprised Tyron won't answer whatever you've contacted them specifically about, well not really, this is after all 2023 and they've already gotten your money. The dealership owners almost certainly self absolved anything resembling accountability from the employees they inherited, kinda makes me wonder how many folks are riding around on improperly installed Tyrons that are under the false impression they'll actually help when they're most needed? I really hate this happened to you and I can imagine there's still plenty of repair work left to complete. I hope your able to get some recourse from Tyron, it sounds like they're very in the wrong through this whole ordeal.
Update - sorry, thought I had added these pics to original post and I have referred to them a few times. First one shows the Tyron slippage on the blown out tire I have mentioned a few times in this and other threads regarding Retroband and Tyron. Second one was taken by tire shop, is the right side (non blowout steer wheel) after removing the Tyron to change tires. Tire shop that FL has replacing my tires says it is damaged by the Tyron install and requires replacement. Not knowing anything about damaged wheels, or having anything to compare to but this and the slippage to me point to a bad Tyron install so far in my book as to what actually happened. Why my tire shredded so badly is still not clear, could be due to the bad install, or not. Mine looks nothing like any example of blown tires with Tyron on their website. Factory tires were 0118 date codes so they were 2 years old before leaving the factory in April of 2020 to head to dealer so there is that. So far no reply from Tyron_USA to any of my attempts to reach them. Was notified an hour ago that RV is ready to move from FL to a body shop still being determined. Total for the electrical repairs was roughly 5K, with another 1k ish for both front wheels, and approx 4500 for new tires all the way around before any body work gets done. I also need to armor up the electronic bay after the fact to hopefully avoid any damage like this in the future. Still not clear what actually happened, but not ready to throw in the towel, and am hoping the body shop can get me back on the road before Thanksgiving. I do plan to get into NIRVC for Retrobands as I dont want to attempt a blowout on a rim again at any speed. No confidence in the Tyrons after this event.
Just heard back from Tyron-USA, they responded with a request for a phone number to reach out to me...I will update once I have spoken to a live person.
