- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
My Victron inverter (24/3000) and Li-ion bank were in the same space in my last two coaches and I installed a cooling fan ducted to the outside with a temp sensor (out of a Fan-tastic Fan) and variable control. But it was another set of complications and I’d rather keep things simple these days.Agreed! But would be a problem in the summer months…. It generates a lot of heat.
If I hold onto my rig, I plan to put in a vent in the basement…. I like the idea of using a fantastic fan control….My Victron inverter and Li-ion bank were in the same space in my last two coaches and I installed a cooling fan ducted to the outside with a temp sensor (out of a Fan-tastic Fan) and variable control. But it was another set of complications and I’d rather keep things simple these days.
Electronics AFAIK are designed to handle the heat, run hot, etc. it’s uncomfortable for us and probably to accept but things like this, pepwaves etc get very hot.If I hold onto my rig, I plan to put in a vent in the basement…. I like the idea of using a fantastic fan control….
Even my Starlink router gets pretty hot. I don’t know how much power it uses (guess I could look it up) but with my house batteries failing I started turning off the inverter at bedtime because that and the fridge are too much for it now. My next trip is an extended stay at a park down south so I won’t need to replace my batteries until next spring, but when I do, it will probably be two BB 8Ds.Electronics AFAIK are designed to handle the heat, run hot, etc. it’s uncomfortable for us and probably to accept but things like this, pepwaves etc get very hot.
