Joe Dutchstar
- Nov 3, 2019
- Florida
- Dutch Star 4311
- Spartan
- Cummins
- 2018 Ford Flex
Why do they call a car 12 volt when it’s actually 14?Very nice. Now if someone can explain to me why everyone calls it 110 when it’s 120![]()
I have one of those, also interesting to see the voltage fluctuations when I run my Breville Nespresso with I think a 1500 watt pump on it.Installed a small plug in volt meter in a rarely use 110v outlet just to keep an eye on pedestal power. This was a meter from Hughes. interesting to see the daily variations.
LOL, I recently read about that when I was trying to get more info on low voltage. Apparently a long time ago, we were 110v, then over time, different areas of US had different voltages, 110 or 115 or 117, and eventually it was standardized on 120 with a +/- 5%, however clearly 110/220 is still used all the time, including by myself, when it's really 120/240.Very nice. Now if someone can explain to me why everyone calls it 110 when it’s 120![]()
Car battery is a 12 volt battery that will show 12.something when fully charged, but we often see 14 volts or so if your car shows volts, which is the alternator output charging the 12v battery. At least that's my understanding.Why do they car a car 12 volt when it’s actually 14?
Is this measuring inverter output or pedestal line voltage? I believe it's inverter.Installed a small plug in volt meter in a rarely use 110v outlet just to keep an eye on pedestal power. This was a meter from Hughes. interesting to see the daily variations.
Just a friendly note. Make sure if you off grid running on batteries only that you remove this device or turn it off as it will drain battery over time. When I redid my coach electrical I added a hard wired dual 12 volt monitor . This allows me to monitor the chassis and house battery lever. I added the switch for two purposes; one to save batteries and secondly because the LED display was reported to be so bright it would illuminate the coach at night. It truly is that bright. Small but mighty. I love having this available to know where my battery status at times. Happy Trails to You!Installed a small plug in volt meter in a rarely use 110v outlet just to keep an eye on pedestal power. This was a meter from Hughes. interesting to see the daily variations.
