It is time...for new house batteries! Likely LiFePO4 - calling all DIYers
The Hoots Rally looks like a good time. I’ll put that on our schedule for 2024
I purchased a SOK for our greenhouse to give it a try. I had previously went with the heated LifeBlues from AM solar when I converted my Tiffin RED back in 2019. Now that I have a Winnebago Navion, I will probably purchase 2 of the heated SOK since their size will fit in the OEM battery tray under the stairs. One thing that I noticed was the SOK seem to charge faster, compared the the LifeBlues that I had. This was probably because the BMS on the SOK was newer and configured to accept higher current charging.
Also, keep in mind that the lithiums do not have to sit flat. You can mount them on their side or on edge, which may give you extra space if standing up on end and anchored to the side wall of your bay.
Picked up the coach yesterday, my typical routine leaving storage is adding required distilled water, tire pressures, etc. The usual 1/2 gal of distilled water on boarded and noticed a few batteries with corrosion on the terminals which I'll be cleaning and coating as was done in the past. Overnight at my house, no loads, SOC down to 69% in the morning, definitely not good or expected while I did dial down the temp of the basement dometic CF-80 cooler to 26 (usually around 10 below actual) to get the beer cold cold cold.
As the coach is getting new shoes (tires) as I type this, I think the winter project is set which may impact winter plans, we shall see. But my desire is to "remodel" the house battery bay similar to @Richpatty with wood paneling and basement carpet per Newmar in other bays and get some LifePO4's installed and the Li BIM. Move all solar equipment into the bay. Watching for black friday sales with Battleborn, etc. but strongly considering building my own per the diysolar forum and his videos. @Ddmo I believe you mentioned building your own so I welcome any info share here as to how to buy, select, build, etc.
So let's switch to LifePO4 together, any inputs, suggestions, etc. etc. welcome. Time to get this corrosion mess out and a house battery bay to show off to all my friends that want nothing more than to look at a house battery bay while camping that I'm sure will be asking to see :)
No solar or inverter changes expected, just batteries at this time unless I'm super convinced and arm twisted. Hoping to find some great deals this shopping season in this strained economy!
make sure the battery has temperature control becauz all lifepo4 batteries are not made with them and can freeze leaving you crying.
FYI…. Battleborn batteries are going on sale….
Thanks - I really wont need batteries until summer but this would save me over $700 so I just might do it. Two 8D’s would do nicely.
There pretty much all on sale. Here’s a 460ah for $1499.
I probably mentioned on the site somewhere but this YouTuber is great to watch and he does battery reviews, etc. and how to build your own:
and this is his forum, also good info to check out:
I was just on that forum yesterday - a lot of good info there.
And...it happened:
While looking into the Lithium myself I came across this company. Seems their prices are cheap, but I don't know much about batteries. Redodo Power—Lithium solar batteries and RV batteries!
They do have one battery that will replace all 4 of my lead acid ones.
I would have a lot of difficulty buying anything with a rainbow plastered all over it.
