SCARY.......Lithium Battery Fires!!
Jabber Jaw
St. Augustine Fl
Canyon Star 3710
Ford F-53, 26,000GVWR
Ford V-10
2017 Gmc Terrain & 2017 Chevrolet Colorado ZR-2
A friend emailed me this video about lithium battery fires! The title sums it up.....SCARY!!!
Especially with many new RV's, Coaches & Fiver's, pull trailers, etc!
And high end coach manufacturers now installing them, when built!
I'm not sure how it will affect the RV industry!
Allan
  • EV VIDEO.mp4
    13.1 MB
Certainly a lot unknown and yes there is risk but this is where LiFePO4 type batteries come into play for safety. But I wonder if/when insurance companies may start charging more or denying policies based on something like this.
A great point Neal! Insurance companies need but a small excuse (reason) to raise premiums anymore!
I do know that I will not be buying a "Tesla", nor any other EV! Mainly because I'm too dang old!;)
Unfortunately it is not understood by the general public that a “lithium” battery is not the same as every other lithium battery.
There are different chemistry batteries, each of them has different pros and cons.
The are 2 lithium ion battery types that have the thermal runaway risk - NMC and NMCA.
There is a different batter type, LFP or LFeP, that stores a little less energy but does NOT have the risk of thermal runaway. This is the type of battery that is popularly used in RVs (and now Tesla China and some Chinese builders are starting to use).
We have two LFeP batteries in our coach, each is 450aH in size. As an illustration of their safety, while an alarm system was being installed one of the batteries was drilled into. It took awhile to figure out why the battery capacity wasn’t the same but there was never any heat or fire for the weeks that this battery was damaged, with a hole drilled into a cell.
I have no concern about LFeP batteries and fire risk based on my crude understanding of chemistry and now experience/knowledge from real life.
There is more risk from the other chemistry batteries, and would not want one of them in my RV or house. Even careful where I leave my phone, especially when charging.
As pointed out. Different Li battery types/chemistry results in varying risk. What about flooded cell battery hydrogen gas explosions? Risk there too.
Reports of Li battery fire in vehicles = sensationalism at its finest.
Our local storage company will not allow lithium batteries or electric vehicles inside the storage units. I would bet insurance has a lot to do with that policy. Some great Utube videos of the electric jeep wrangler exploding. When the battery does fail it vents explosive gases into the passenger compartment and then explodes with a very impressive result.
Allan
The clip sounds like a little political posturing is being included but, no matter, I will not charge our e bike batteries anywhere near the coach and I have the chargers connected to a timer. Owners manual says max charge time four hours. I have it set for three. I think the world is rushing the use of Lithium Batteries and the world leaders aiding the push is wrong.
Darrell
WOW...as commentator willing to tell it like it is...we could use a few more of those types in my humble opinion.
I will move my e-bike a little further away from our motorhome while charging in the future however 🤔
Neal you're spot on!!! Rates are already higher on EV KIA products due to fire risk. At this time I would not keep the fact you have lithium batteries as house batteries from your insurance company. When you tell them, they may want to know if your system is DIY, or professionally done. In this you did good!
Another comment made on chemical reaction causing the fire is bogus!!! The fire is electrical in nature, and as long as there is power, and heat to compromise the cells, it is impossible to put it out!!! The job of a fire crew is to keep water on the site until It has cooled down. We all know water does not react well with electricity, so we know they won't put it out, just control collateral damage.
One more thing! Lower risk doesn't mean no risk. I was shown videos of LTO batteries having holes drilled in them, many in fact!!! Then it happened! Low risk? Yes, no risk, no!!!
A lithium battery fire is classified as a Class B fire not Class C. If you ever need to try and put one out use a extinguisher with class B rating. Most are ABC rated.
Heat has different impacts on the cells, depending on the chemistry. This is why some lithium battery types have “thermal runaway”, one cell exploding (due to the chemistry type changing size in a non-linear way as it discharges/charges) then causes the next cell to overheat and change size, discharge too fast, then damage the next cell…
Look at this from Wikipedia:
“As lithium migrates out of the cathode in a LiCoO2 cell, the CoO2 undergoes non-linear expansion that affects the structural integrity of the cell. The fully lithiated and unlithiated states of LiFePO4 are structurally similar which means that LiFePO4 cells are more structurally stable than LiCoO2 cells.[citation needed]
No lithium remains in the cathode of a fully charged LFP cell. In a LiCoO2 cell, approximately 50% remains. LiFePO4 is highly resilient during oxygen loss, which typically results in an exothermic reaction in other lithium cells.[18] As a result, LiFePO4 cells are harder to ignite in the event of mishandling (especially during charge). The LiFePO4 battery does not decompose at high temperatures.[32]
The point is: one lithium chemistry battery type is not the same as another. When we see stories of runaway lithium batteries it is almost always one of the other battery chemistries (not LFeP).
Can LFeP batteries burn? Sure
Can lead acid batteries create hydrogen gas and cause an explosion? Sure
Can stored gasoline in a can explode? Sure
Lithium isn’t causing some uncontrollable big risk, anymore than gasoline is causing a risk. We need to understand the risk and how to mitigate the risk. I realize that sensationalism gets clicks/views and generates revenue. Just want people to realize that the LFeP batteries that may be in our RVs are not as dangerous as that video originally posted may lead some people to believe.
We all have our opinions and views, want to help alleviate unnecessary worrying and help educate on the very different lithium battery types and risk levels between these forms of energy storage.
"We all have our opinions and views, want to help alleviate unnecessary worrying and help educate on the very different lithium battery types and risk levels between these forms of energy storage."
Name the time a can of gasoline spontaneously exploded? Name the time a gas tank in a vehicle spontaneously exploded? Don't even bother to step around the question by talking about Pinto's and such. Gasoline can sit in a can until it isn't gasoline anymore and will not just decide to explode or combust. When is the last time you heard of a ship full of cars catching fire and sinking because the gas in the tanks just caught fire? To call videos of rechargeable batteries regardless of type exploding sensationalism is a huge deflection. Typical of the EV fans when discussing range, charge times, and charger availability. I have a can of gas, a car, a motorcycle, and a generator in my garage right now, along with other flammable liquids. None of them and I mean none, will start a fire on their own. They may accelerate one if something else catch's fire.....like my Makita and Milwaukee batteries or the battery tender on the Goldwing.
Agree that a gasoline can won’t spontaneously combust. It needs a heat source. I have been monitoring and continue to read and have yet to read about LFeP spontaneously combust. Other types of lithium batteries, yes.
The point is that there is a difference in types of lithium batteries - all types of lithium batteries do not carry the same risk.
The batteries that were on that ship were the higher risk type. Again, don’t want people to panic and think the LFeP in their RV is going to burn down tonight.
And to clarify, I don’t own an EV vehicle.
Take the time to research how the professionals manage lithium fires, I have.
