Question 2024 DutchStar head light bulb replacement LED
Did you have any fit issues?
No fit like OEM, I ordered 2 sets not realizing the inbound lights are turn signal lights
So one set is all you need
Another thing I did was to shim the fog lights so they could be aimed higher
I went with these and like the outcome on my 2023 DS
I need to change mine also, cant believe i had one burn out at 1 year. I briefly glanced inside and it looks like the whole light fixture comes out the front to change the bulbs, correct? I cannot find any info on changing them, any links?
No directly behind the headlight, outbound light, there is a round cap with a rasied flat. Turn cap 1/4 turn to remove
What is the correct bulb size/designation for the 2024 DutchStar?
Not positive on 2024, it looks the same as 2023
I listed the bulbs I purchased earlier in this thread for my 2023
From The Newmar Parts Catalog the 2024 DutchStar headlight bulb looks to be a Sylvania Vendor Number #9012SU-2.
Thought I'd try these
Amazon product ASIN B0CLGY6PNR
And a review
From NEWMAR Parts Cat.
9012 is the same for 2023
I think RB did a complete writeup on that some while back. hopefuly he is around and provide more detail info. from what I can remember, the LED bulbs are designed for an 'LED' headlights. The ordinary headlights bulbs are designed for their own specific headlight. This has to do with how the light is spread. You can use an LED in a regular headlight, however, the light will be spread such that it becomes an irretant for the oncoming traffic. An LED headlight will focus the brightness of the LED bulb accordingly, so it is not an irretant for the on coming traffic.
It may be better to replace the entire headlight with one designed for LED.
Other option, 'owners' should consider writting Newmar new pres. and asking if he has driven his newmar at night? If no one ever writes these people about such short comings, such problems will remain for eternity.
Anyone have Casey’s email???
I changed both dim and high beam bulbs on my 2015 Ventana with no issues. Got them on Amazon. Napa was $150 for 2 bulbs...Amazon was like $60 for 4...same bulb for all 4
I have Lasifit in my Ventana, dim and brights. 100X better than stock. I can't believe any coach should leave factory without LED lights all the way around.
Ended up purchasing and installing Fahren bulbs. They seem to work well. Fitment not an issue. Went right in.
Just to tie up loose ends. The Fahren LEDs expired early. Six months and LED is dead.
Not sure if it was vibration, the harsh ride, or just QC, but one died.
Back to Sylvania Silverstar for now.
Met Jason Maybie here at Newmar AKA RVHEADLIGHTGUY. He works in engineering and has a side business building very highend headlights, mostly for DutchStar.
He explained much of the issues with LEDs in the OEM housings.
Back to square one on the headlights.
Not sure I want to drop $3k on custom, high-end custom headlights. We’ll see. Pun intended.
Just curious. How late are most of you on the road? You say you try not to drive and get in late. What is the latest you have wound up getting in?
4pm , I try to arrive before 2:30pm
