• Something exciting is coming soon...
Question 2024 DutchStar head light bulb replacement LED
Try M4 products. My LED headlights were a whopping $84 and simply amazing. Illuminated everything and on coming drivers never flashed their lights at me. M4 LED Products
Fahren's in 3 vehicles, love them, no issues. Sounds like you had a bad one. I'd just replace it and keep a spare, if you were happy with how it worked for you.
So the DutchStar headlight output is again measured in Candlepower 😂
The Flex LED driver side headlamp is now intermittent. Driving my nuts. Left wing conspiracy!!!
The Lasifit have been in mine 2 years...25k miles....and I drive at night some
Met Jason Maybie here at Newmar AKA RVHEADLIGHTGUY. He works in engineering and has a side business building very highend headlights, mostly for DutchStar.
He explained much of the issues with LEDs in the OEM housings
This, I believe, is the root cause of headlight issues on Class A.
There hasn’t been enough engineering thought in the headlights. Just grab something off the shelf that wasn’t designed for the height position for where they mount it nor thought into the overall mass of the vehicle and stopping distances.
Headlights designed for the chassis is one of the benefits of a class c chassis.
If you don’t drive at night, then these are only for emergency use, just drive slower when dark.
The prior owner of our coach (Freightliner Cascadia based Super C) upgraded the headlights to LED. They swapped out the entire housing to ensure the housing and reflectors were designed together to maximize the lighting.
Love the headlights. Work well on low beam, great on high beam, and when on a long country road without cars will flip that other switch for the light bar, then we can see down the road in almost daylight conditions for more than 1/2 mile.
It might seem pricey to swap out the entire housing, but if you want to drive at night, might be worth considering this route and see if you can see a real life demo of the difference.
In the overall scheme of the coach price, $3k for total headlamp housing doesn’t seem too bad. But Newmar, IMO, should be considering these as standard or making them a factory option.
The LED bulb installed failed either from cold weather or time. Prior to going custom headlamp housing build I am going to try a brand that has worked well for me in the past.
  • LED Bulbs: 2x (One Pair) 9012 Ultra 2.0 LED Bulbs
  • LED Drivers: 2x Ultra 2.0
  • Wiring: 9012 Plug and Play Inputs
Here are the bulbs that are being replaced in the 2024 DutchStar. Poor excuse for a headlight bulb.
Getting into the weeds on this headlight issue. The Sylvania bulbs are very yellowish which has me questioning the power source. The wiring diagram appears to show the housing acting as the ground and the two wires connected to the bulb as one wire high and the second one low beam.
My question is the housing ground? The housing is attached to a fiberglass front facia? Where is a solid ground for the housing? There is "A" ground as the light does illuminate but how good of a ground?
Thoughts on how to determine quality of ground?
Connector
Next steps :
From Internet:
Verify Automotive Ground
To verify an automotive ground, you can use a multimeter to check the resistance between the ground wire and the vehicle's chassis. Set the multimeter to the ohm range and touch one probe to the metal chassis of the car and the other probe to the ground wire. The reading should be 0 ohms, indicating a good ground connection. If the multimeter shows any resistance, the ground wire may be faulty and needs to be replaced
It's important to ensure that the grounding point is free of paint, rust, or plating, as these can prevent a good ground connection Grounding an accessory to the engine should ideally involve running a ground wire directly to the alternator case and ensuring there is no paint between the starter and the engine block mounting surface
Additionally, a quality ground point should be bare unpainted metal, allowing for electromagnetic waves to travel and complete circuits without interruption Poor-quality ground points, such as those covered in rust or paint, can act as a resistant coating or insulator, reducing conductivity and potentially causing devices to function intermittently or not at all
For best results, locate existing factory ground points on your vehicle, which tend to look like bolts or metal studs, and ensure they are bare metal If necessary, you can sand off paint or rust to expose the metal
Next steps :
From Internet:
Glad I don't trust everything I read on the net!
Here is the GROK ground testing comments:
Verifying automotive grounding systems is critical to ensure proper electrical function, prevent component damage, and maintain safety. A faulty ground can cause issues like dim headlights, erratic sensor behavior, or even failure to start. Here’s a concise guide to verify automotive grounds using a multimeter, based on standard practices:
Tools Needed
  • Digital multimeter (set to ohms for resistance or DC volts for voltage drop)
  • Wrench or screwdriver (to access ground points)
  • Wire brush or sandpaper (to clean connections)
Steps to Verify Automotive Grounds
  1. Safety First
    • Park the car on a flat surface, engage the parking brake, and turn off the ignition.
    • Disconnect the battery’s positive terminal to avoid electrical shock or short circuits, unless testing under load.
  2. Locate Ground Points
    • Common ground points include the battery’s negative terminal, chassis, engine block, or alternator case.
    • Ensure ground points are free of paint, rust, or corrosion, as these act as insulators.
  3. Test Ground Resistance (Ohms)
    • Set the multimeter to the ohm (Ω) setting.
    • Connect one probe to the battery’s negative terminal and the other to the ground point (e.g., chassis bolt or engine block).
    • A reading close to 0 ohms (typically <5 ohms) indicates a good ground. Higher resistance suggests corrosion or a loose connection.
    • Repeat for other ground points, noting that resistance may vary slightly (e.g., engine block may read lower than a rear chassis point).
  4. Test Voltage Drop (Under Load)
    • Reconnect the battery and turn on the ignition or the component being tested (e.g., headlights).
    • Set the multimeter to DC volts.
    • Place one probe on the ground point and the other on the battery’s negative terminal.
    • A voltage drop <0.05 volts under load indicates a good ground. Higher values suggest a weak connection needing repair.
  5. Visual Inspection
    • Check ground wires and terminals for corrosion, fraying, or loose bolts.
    • Clean corroded surfaces with a wire brush or sandpaper and tighten connections securely.
  6. Fixing Bad Grounds
    • Replace damaged ground wires or straps with appropriately gauged wire (larger gauge for high-current components like audio amplifiers).
    • Ensure direct metal-to-metal contact at the ground point.
    • If issues persist, trace the wiring harness for breaks or consult a mechanic.
Common Signs of Bad Grounds
  • Flickering or dim lights
  • Engine stalling or rough idling
  • Malfunctioning electronics (e.g., ECU errors, low fuel pump pressure)
  • Audio system noise (e.g., whining in speakers)
Notes
  • Always use a multimeter for accurate testing; test lights can damage sensitive electronics like ECUs.
  • For complex issues (e.g., intermittent ECU communication failures), check wiring schematics or consult a professional, as high resistance (>0.3 ohms) between cab, frame, and engine can cause problems.
  • Regular maintenance, like cleaning battery terminals and inspecting grounds during service, prevents issues.
If you’re not confident or encounter persistent issues, take the vehicle to a qualified mechanic to avoid further electrical damage.
Reminds me of seeing a car from behind with the lights on, then hits the brakes and one side goes dark. = Bad ground.
