Where are the house batteries?
Robrem108
Taos County, New Mexico
Roadtrek
Zion
22 ft
Ram Promaster 3500
I have a 2016 Roadtrek Zion and I'm having trouble with my electrical system. I need to find the AGM batteries. Does anyone know where they are located. I have hooked it to shore power and getting no charge to the batteries. Last winter this was working. It's a Promaster 3500 with extended body.
My engine battery also drains if it has not been started in a few weeks. I am trying to figure out if the slide out steps are still pulling power when in, or if there is some power leak between the under-hood generator and the engine battery. Any ideas or similar problems?
I'm not sure yours is the same, but I have a 2021 Zion SRT (Promaster 3500), and I took a look at the underside of the unit and could easily see the two LiFePO4 batteries as well as the AGM one. The AGM one was in the center toward the rear. The lithiums were forward of that, side by side.
I found this video online that shows the underneath side of the RoadTrek Zion which shows where the AGM batteries are located.
I know on our Zion the chassis battery is located under the floor on the driver side. Where your feet rest when driving. If you pull off the mat there are clips that turn to take off a cover that covers the battery is underneath.
Hope this helps!
Yes, many of the non LI vans have their house batteries underneath. Also have the generator hanging down under there. Many have hit their generator on high spots in the road
Hope this helps!
Hope this helps!
I just bought a used 2021 road trek Zion slumber with lithium batteries, and having some electrical problems. First the firefly Vega touch screen would not work. Once connected to shore power it works, but 12v features don’t get power. The firefly did show 2 fully charged lithium batteries (13.7v). Thinking the firefly G12 was bad (12v) J3 module, I contacted Firefly and they sent me a firmware update. With the new upgrade, more options are avialable for troubleshooting. I turned off the lithium batteries, and disconnected shore power, forcing the system to use AGM batteries. All 12 volt features started working, but it quickly drained the AGM battery.
I believe AGM is not holding a charge, but does show charging when plugged in. Trying to determine how for lithium batteries can be engaged successful. Is this an inverter issue or so meh if else?
I'm new to this forum and late to see your post. We just purchased a 2021 Roadtrek Zion SRT and found that, with the Lithiums turned OFF at the Firefly, the 12v system still functioned. From what I have found, this should not be happening. In your post you state that you forced the system to use the AGM batteries and 12v features started working but drained the battery. My question is - should the AGM be providing 12v power if the lithiums are OFF. From everything I've seen/read/been told, the answer is No. Do you have knowledge that it should?
