The breaker on the pedestal seems like it's okay, I did try to reset it and there was resistance. This is the second park that we have issues with so I was assuming it was me. Also my electric heater is not working correctly.When you say 30 amp adapter, are you taking the “dog bone” 110 plug on on side and 30 amp on the other? If so as Kevin said check the pedestal 50 amp breaker, 110 is a separate breaker
Resistance?The breaker on the pedestal seems like it's okay, I did try to reset it and there was resistance. This is the second park that we have issues with so I was assuming it was me. Also my electric heater is not working correctly.
He checked the cord as soon as he plugged in the dogbone and things worked!I would check continuity of each leg of the cord using a multimeter at each prong and the associated screw where the line is attached to the rig. Also, check to be sure the attachment screw is real tight. In many cases they can loosen over time
Ok op org post said works with 20 amps now I’m reading 30mp Given this it sounds like an open neutralSo we have a 2004 journey and on our current trip, I have plugged our 50a cord into shore power and I get nothing but when I plug my 30a adapter in it works fine.
Send us you reasoning!Ok op org post said works with 20 amps now I’m reading 30mp Given this it sounds like an open neutral
Sorry I was wrong on the open neutral. Here is what I think is the issueSend us you reasoning!
Clarification: RV 50A power, is actually 2 legs of 120V electricity.Sorry I was wrong on the open neutral. Here is what I think is the issue
When you connect the 30 amp adapter you’re taking the one 30amp 220 lead and feeding both 50amps legs of the coach. Hard to say without actually checking it ,but if “everything works” with the 30 amp adapter as the op is saying then it really indicates a problem with the pedestal. I say this because the 30 amp adapter is getting 220 to the 50 amp plug if everything works. And if both 50 amp circuits in the coach are getting power from this arrangement , it indicates when the op plugs the 50 amp plug in to the pedestal one of the 220v circuits for the 50 amps is dead. What are your thoughts?
