- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
As are we! So far so good.@J&JD - glad you missed the storms and giant tornado ahead of you.
What is needed is a 250A continuous duty solenoid. Cole hersee sells a 200a for $75 on Amazon. I carry that and use it as an emergency. As long as you keep your RPMs high while extending slide the amp will be low due to higher
Interestingly, my FWS will not operate with the engine running. That’s one of the things I’m going to discuss with HWH.As long as you keep your RPMs high while extending slide the amp will be low due to higher
If/when you have time, can you provide a link or part number, there are a gazillion on Amazon. And where is this critical part located in the coach and what is its function so I can understand better, and it's relation to Active Air.
There is a lockout that was moved in 2019 to the parking brake. Prior years it was ignition based.Interestingly, my FWS will not operate with the engine running. That’s one of the things I’m going to discuss with HWH.
I will also discuss the solenoid with them.
Ok, @Neal, we realize now that you are finally getting back at us for harassing you about your Ventana/snow/snow Sox adventure. Good call!Tornado pics on Facebook now, this is someone posting the tornado that was just north of Lincoln.
Just FYI Truck Center in Lincoln on Arbor Rd at 1-80 (exit 405) is an excellent honest Freightliner shop and they are open and working 24/7. They worked on mine overnight on a Friday night and I was back on the road on Saturday. Hopefully you wont need them for anything but since you mentioned Lincoln I thought I’d let you know. Where did you stop for the night in Lincoln?@Neal and @redbaron , thanks for all your comments and help. We have made it to Lincoln Nebraska from the Bay Area (1700 miles) so far managing this crazy system. The last leg to HWH hopefully will be finished tomorrow with a Monday morning appointment there. I will post a full report when we get this darn thing diagnosed.
Thanks again!
We are at Camp-A-Way in Lincoln. Thanks for the Freightliner info but we seem to be ok. Was able to get level without deploying anything so hopefully the slide will come in just fine. They look good so far.Where did you stop for the night in Lincoln?
I thought so - we stayed there too. Nice mature park nestled in the SW corner of a clover leaf, but for all that it was peaceful and pleasant.We are at Camp-A-Way in Lincoln. Thanks for the Freightliner info but we seem to be ok. Was able to get level without deploying anything so hopefully the slide will come in just fine. They look good so far.
Thanks again for checking in.
A couple of outcomes I guess:What was the outcome @J&JD?
