JRS
RVF Expert
- Jan 25, 2020
- Full timers
- Dutch Star 4328 - FL Chassis
- 2018 Jeep Grand Cherokee
- Yes
My summer loop pump failed and yesterday I installed a US Solar Pumps C1E 12V 20L Circulating Pump (nothing new here). As reported by others, it's not a difficult job. What is new now is all three pumps have the same outlet/inlet positions on newer Newmar Rigs. So, the aforementioned pump is a direct replacement for the Loop 1 and Loop 2 pumps.
Here's a great link on changing the summer loop and zone 2 pumps. He had to use a longer hose to make the above pump work for the zone 2 replacement which is now not an issue on newer rigs.
www.irv2.com
Here's video on changing the summer loop pump. He used the more expensive OEM pump. While not as useful as the link above, it's worth watching.
Where I purchased the pump. Many have recommended this pump.
www.ussolarpumps.com
Oasis Pump Change in Pictures
There are lots of threads on Oasis pump changes which helped me a LOT in recently having to change my summer loop and zone 2 pumps. But one thing I did not understand going in was the hydronic fluid flow directions or how fluid flowed through the system to be sure I knew what to clamp off, etc...
C1E Circulating Pump | US Solar Pumps 2026
C1E Circulating Pump is part of our C series micro centrifugal pumps. It is a 12 volt 20 litre pump. It is designed to be quiet, compact and lightweight.
