TXfreeze
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
Yea sorry about that , here's a landscaped picture attached as you can see I've removed the main breaker and Air Con breaker and detaches the corresponding wires and detaches one of the damaged wires from the bar, this was before I saw you reply. We don't have Home Depot only Lowe's and Harbor Freight, so I'm going to see if I can get replace the 2 breakers get some 30amp rated copper wire and wire nut but I may not have to since there seems to be some slack in the wire harness I may just be able to strip and pull out good wire. Will keep you posted. ThanksTalk about not seeing the forest through the trees!
Turn the phone on it's side, and give us a full picture of the wires! You give us burned wire, but no full picture. My eyes keep running off the picture while trying to trace the wires! I am afraid I will damage My eye's when they fall
From what I see, the white (neutral/Common) wire along the bottom has lost it's insulation. The worst of it is closer to the neutral buss bar. That is common when screws are loose.
I would get a new bar from home Depot that will fit in the box, and land the neutrals on the new bar.
Any fried wires that will not reach when shortened, simply wire nut a pigtail to it so it will.
Takes time,but it's not rocket science.
