TXfreeze
- Jan 6, 2021
- Holiday Rambler
- Endeavor
- Roadmaster
- 350 Cummins
- None
- Yes
We've been smelling electrical.burn smell and thank the Lord we found out what it was before we had a catastrophe on our hands. The fuse box was where the smell was coming from and temp readings were as high as 112 F. I turned off the main breaker and let it cool down. After the temps cooled down and when it got down into the 90s I turned it back on and when the breaker switch was touched we heard a sizzle bees like sound and shut it off. We decided the best thing was to keep it off for now and turned off the 30 amp on shore power just to be safe so we're currently off grid but paying for power. Attached are a few pictures of the wiring where you can see one of the wires is damaged. As to how this happened we have a theory that when the AC was running and the compressor was struggling there was a significant amount of heat in the fuse box and that may have caused the damage and continuing to use the blower fan alone may have aggravated the situation. We don't have a RV repair in the area the closest will charge $100 just to come out so if there's any way to DIY, Lowe's should be open tomorrow and should be able to pick up the necessary wiring.maybe splice in new wire?
