- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
I admit I don't do this often, maybe once a year I'll put Clorox in the fresh water feed line and then fill the fresh tank. I've heard of other chemicals being used, variations in how often it's done, etc. I guess too climate (heat) matters, if I was in Florida I'd probably do it more as the heat may make things grow more than other climates. I also try to rotate my fresh tank when I can by using the water pump even when on city water to feed the water out of the bottom of the fresh tank. Where I am now in sunny warm freaking cold Arizona I'm actually filling fresh then disconnecting the water softener and stowing it, stowing the city water line and running the fresh tank near dry before the next fill.
Do you sanitize your fresh water tank?
How often?
What chemicals are you using and how much?
Do you drink that water or drain it then refill?
