- Jul 27, 2019
- Midlothian, VA
- Ventana 4037
- 40' 10"
- Freightliner XCR
- Cummins 400 HP
- 2017 Chevy Colorado
After 8 months I’m finally on the road again. Decided to head to the airshow in Oshkosh, WI as I’ve done the past few years. I have to be back by Labor Day so time is limited so destinations are limited. Made it to my usual stop in Milton, WV and all was green. Unusual. Something is usually wrong and needs fixed. Other than a major hoarding reorganization internally the two night stay went well.
Then the departure this morning. Yep. Here we go. RV life isn’t all joy. I pull out and get a yellow outline engine symbol. Great. I’m fearing a red light and derate next. I luckily get out of the campground and a parking lot across street I pull into and dive for the regen trip connector. Nothing. Okay. Call 1-800-FTL-HELP. Quick answer but got disconnected. Call back, different agent and she helps me with the code which is the ECM got a low voltage hit on the DEF doser. I had this a few years ago and it cleared after 4 engine cycles so I drive on.
Now 3 hours in and crossed into IN I get a yellow check engine light. Luckily an exit is near and I pull off and to the side of the road and right near an entrance to a campground but that’s moot. I call FCCC again several times between 12:30 and 1’ish and no agents available. I tried the regen plug again and nothing. So I pull my diesel laptops scan tool and as I type a regen is running and check engine light is out. I wanted to do a regen after sitting for 8 months but didn’t. Let’s see if it manages itself. Maybe it’s bad DEF. It was stored full.
Codes attached but I’m still waiting for a call and for the REGEN to complete. It could be some time. Any help with the codes is appreciated.
I’m too old for this!!!
