Water pump kaput
Notsotalltexan
San Antonio, TX
Fleetwood
Discovery XLE
Cummins 380
2021 Jeep Wrangler Unlimited
Greetings from Pine Hollow Campground in southern Vermont!
Water pump not working. Green led lite doesn't come on when switched. Pump led on the controller illuminates when pump switch is pressed but goes off when switch is deactivated.
10 amp pump fuse is good.
Help is much appreciated.
Laurent
If the picture is of the Latching Controller, it needs replacing.
Yes to spare. But the water pump is a simple two wire 12V connection if you want to test and bypass the controller. Just attach to 12V and see if it runs.
Don't do like I did. Looking for my spare water pump but couldn't find it. Ordered a new one and found my old spare when I was putting the new spare away. Now I have two and a spare controller.
That's why I have a dozen or more 10mm sockets.
Thank you Neal. Will do.
