- Nov 3, 2019
- London Aire 4551
- Spartan
- 2020 Jeep Wrangler Unlimited Rubicon
Still under FL warranty as well.Don't forget taxes and maintenance, add all that back in too...you will still be under valued in this market.
Also, Neil I see you have the HWH Active Air. How do you like it? Was it worth the money?. We get a lot of swaying back and forth in campgrounds with rough roads, and sometimes on some uneven roads. Does the active air stop that?Still under FL warranty as well.
So, if I read this right, you’re willing to go coachless for a couple of years, correct? Don’t know if I could do that.Yep, I'm going to remove all that and be prepped to save their time. I just did all that when I removed the units myself into the bathroom to get into my washer to check for problems. So again, I think the $140 is well spent for the labor, I just have to decide if I want to replace the two units and with what, Whirlpool recent or Splendide. Just trying to figure out if I want to take a swing at selling this coach after my Newmar visit which will be "newed up" again with a new windshield, new upholstery, new carpet. Not sure what I could realistically get for the coach, that's for another topic, with all the mods, some of which are major. Just want to capitalize on the sellers market if the opportunity presents itself but I'd probably have to wait 1-2 years to re-enter the RV market.
DW is way ahead of the curve on this one @Neal. She is very careful of how the washer & dryer are loaded. I’m not even allowed to load them as she knows I’ll screw it up. Maybe you need a knowledgeable travel companion to help with these tasks. Elli may not be the answer, at least not for loading the washer.Loads of laundry continue to be just fine. While the door lock issue was real, easily fixed by bumping out the back side with a few washers, the other issues I do believe are user error - putting too much clothes in a compact washer. With the proper discipline of using the whirlpool washing machine properly it appears to me it works just fine. Time will tell, I have between now and end of Sept for my Newmar service visit to see how things go. But they've been going just fine with the knowledge above.
Only 3+ years of use to figure it all out….not bad @Neal. Good thing I have an intelligent DW that keeps me straight on this type of stuff. Hope the washer keeps chugging along so you won’t have to trade for that Essex???Two loads today and still running great. So as of now sticking with what I have. I think the crucial part is using the machine properly, not overloading it.
how do you get the washing machine in/out of the coach?
May I ask how you took the pocket door off? We're trying to install a washer/dryer in our 5th wheel and the opening with tuhe picket door is 1/2" too narrow. How do we get the door off? TIAYou're lucky to have the room to get a 24" machine in and out. I have 22 1/2" and that's after removing the pocket door into the bathroom. I've searched and there is not many (two) REAL washers that fits that dimension - Panda just came out with one. I say real because there are a couple .9 or .6 cu ft, like hand washing in a sink.
Late to this party and dont feel like reading the last 53 posts. What issue(s) are folks having with the stacked washer/dryers?Two loads today and still running great. So as of now sticking with what I have. I think the crucial part is using the machine properly, not overloading it.
@Jim - You'll know when it's time because you'll be tired of the nuisance. We replaced our aging Whirlpool POS washer last week with a fancy, new Splendide. Jeanette loves it...'nuff said. The replacement process was fairly simple - just hire a couple of muscle-bound neighbors and supervise closely to protect doorways and new upholstery. Painters' tape on the doorways helped. BTW, if you have to remove the washer for repairs, just go ahead and get an new one...doesn't cost that much more!So @Neal, is the washer still working?
The washing machine in our rig stops working in the middle of a load of clothes. Error code is A-10. I can generally turn it off, restart it, and it’s fine for a while. It’s always been a little quirky and we’re at the point where we either need to get it looked at or get a new on. The washer is original to the coach, so that makes it 8-9 years old.
It’s a Whirlpool and I don’t know if I should just toss it or spend the money to get it repaired.
