Texas Clodhopper
- Nov 16, 2019
- Garden Ridge, TX
- Ventana 4369
- Longer daily
- Freightliner
- Cummins
- 2022 GMC Canyon AT4
Hey, at least the 3rd Lithionics battery has gone from $14K down to $9.9K...They are insane. I am all in for $2!
Good luck Newmar.
Given this all runs on RV-C (similar to CAN-bus) one "should" be able to mix/match components on the network given every module has to comply with the published standards for that type of device (i.e. shades, ACs, tank sensors, etc.). I would think we could leave what we wanted to with existing SilverLeaf modules and swap out what we wanted to with the new private labeled ATC modules. An upgraded new main control panel and mobile phone app experience would be ideal...Yeah, that is so not SilverLeaf. A nicely laid out UX? So jealous already...
You're thinking Mr. PotatoHead of the RV world?Given this all runs on RV-C (similar to CAN-bus) one "should" be able to mix/match components on the network given every module has to comply with the published standards for that type of device (i.e. shades, ACs, tank sensors, etc.). I would think we could leave what we wanted to with existing SilverLeaf modules and swap out what we wanted to with the new private labeled ATC modules. An upgraded new main control panel and mobile phone app experience would be ideal...
Newmar!!! Hello? You listening?
Best,
-Mark
I hear they will have one at Hoots this year.Newmar’s Tubman: ‘Freedom Aire’ Expands Luxury Brand
Pure speculation: Given it is on the new 4500 chassis, which allows for 1,073 lbs more carrying capacity than the 3500HD chassis, and that the CCC in this new offering is still rather low (750-800) and in the neighborhood of those built on the lower capacity 3500HD in prior years by other manufacturers, it suggests this new offering may be built ground up by Newmar using their construction materials and techniques vs. simply a rebadging and paint spray of previous Winnebago Sprinter-based class C's. I'd expect a Navion, for example, to have its CCC jump up to almost 2K if put on the new chassis. If anybody happens to get one, the perfect TOAD is an older manual transmission Fiat 500 given how small and light it is.Newmar’s Tubman: ‘Freedom Aire’ Expands Luxury Brand
@MarkMaxPayne ... What about a 2-door Jeep Wrangler?If anybody happens to get one, the perfect TOAD is an older manual transmission Fiat 500 given how small and light it is.
That will work just fine, Steve.
Just playing with numbers. I'm a victim of "new math" in the 4th grade so be gentle...
Well I think my 2024 Wrangler is about 4,375 lbs ... so this might not work for me. Will have to wait till they publish more information.Just playing with numbers. I'm a victim of "new math" in the 4th grade so be gentle...
If the new Sprinter 4500 chassis has the GCWR still at 15,250, but its GVWR, fully loaded (and you know Sprinter-based RVs are always fully loaded <grin>) is 12,125 lbs, that leaves only 3,125 for towing. Leave the doors, hood, detachable roof, floor mats, spare tire, and fuzzy dice at home?
Smaller? Not meHe lost me when he said the Newmar owners are aging out and want smaller units. How dare he, aging out!
thats what she saidSmaller? Not me
Did anybody find out it they sold out this year? @sheridany @NealOne barometer used for years when I owned a Newmar was did they sell out the entire production run to dealers? For years they did without a blip.
