AbdRahim
- Dec 25, 2019
- BayStar 3626
- 37’
- Ford
- V10
- None
I liked that place. Haven’t been there in years. Thanks for the tip on flooding. I was on top of the hill. Will make sure I request that again next time.Walnut Hills campground in Staunton, VA. It’s an older campground with a new-ish section called the meadow that is mostly pull thrus and can handle the largest of rigs. My site was 80’ long. The traffic pattern to get to this section of the CG is quite the chinese fire drill. You have to loop through the CG and head out as if you’re leaving. As we learned on this outing, parts of the CG flood View attachment 28496when heavy rain passes through. Several folks had to relocate within the CG. Other than that, not a bad stopover if you’re traveling along I-81.
