That's great news on both counts. LadyDi and I are glad that Alfie is showing improvement. Our furry kids mean so much to us and when they're ailing, it hurts.
As for the question regarding the "pedestal," it could be either a problem with your specific pedestal or a broader system issue. If the problem is in the individual pedestal, it could be bad wiring (loose or corroded connections), a failing breaker or a bad ground connection. Moving to a different site with a properly wire pedestal could resolve the problem.
OTOH, if it is a system problem, there is simply not enough power capability to support all users at peak use times. This is where the Autoformer does its magic. It is simply an automatic transformer (hence Autoformer). When it detects voltage sagging to a preset level (too many users at a given time), it boosts the voltage up as much as 10%, if needed. So, for example, the incoming voltage drops to 110V, the Autoformer would boost it to 121V (110V + 11V boost = 121V). No need to go into the actual physics of how it does this; suffice to say that it does.
So, where does the extra 11V come from? Electrical power is measured in Watts and has two primary components; voltage and amperage (we will ignore phase and resistance as they are not important to this discussion). Ohms Law defines this relationship.* For a given amount of Watts, when voltage goes up, amperage goes down. So, the extra 11V comes from a reduction in available amperage.
In the voltage boost example mentioned earlier (110V to 121V), the Autoformer turns amps to volts, so the new 121V will only be able to draw a maximum of 45.8A instead of the normal 50A before tripping the breaker. This should not be a problem as long as you realize that you need to watch your power use a little more carefully; no three ACs running while simultneously running the induction stovetop and microwave at the same time. Probably not a good idea anyway.
Now, that was an attempt to explain the process in non-technical terms. A physics professor or master electrician (neither of which am I) would probably quibble on a few technical points, but I think would agree with the end result.
Happy Saturday to you as well.
Watts/Volts/Amps/Ohms conversion calculator
