How To Replace a summer loop pump in a ITR OASIS Hydronic heater
Seems he's the cause!
You know the shop foreman at Ocala Freightliner?
No, I know the shop foreman at Freightliner Gaffney.
Is the ITR or Solar pump better for pumping Kentucky Bourbon?🥃
just trying to keep the thread on track….
A voice of reason breaks through! What's up with that???? :)
Thats it!! The ITR pump is a food-grade pump.
I’m pretty sure that turning on the bypass switch does just that, it bypasses the pump control and turns them all on at the same time. That is why, if you have no or intermittent hot water or heat in one zone, everything seems to work. You could have 2 of the 3 pumps be bad and the system would work with just one pump, just not as efficiently.
After speaking with Randy at ITR, he confirmed that this is the case.
These pumps are no more than over priced aquarium pump, only thing that make them different is there 12 volt. If they really wanted to fix the problem they should sell the impeller. I've owned a aquarium shop for yrs and took one of these pumps apart. The coil hardly ever goes bad, the magnet on the impeller gets weak.
So my luck finally ran out. My summer pump died yesterday after arriving at a campground…. All three pumps were originals, so I was on borrowed time. But I do not use my rig as much as you guys (we just don’t get out as much as we would like) so that might be part of the reason.
Anyway, I had a spare from ITR from many years ago and it fixed the issue! I have the Oasis NE-S which is a bit different to work on, but probably easier, as all three pumps are right in front of me when I take the main panel off (the unit does not have a separate dist box). See below.
Anyway, I will buy another spare for when the summer pump fails next or if one of the circulating ones die. Looks like I can get one for $279 at heatmyrv.com. Is that a decent price?
No. I think I paid 250/ea from ITR but I'd get the ones from US Solar or wherever it was, discussed on this site, for far cheaper, same pump, despite ITR says it's not.
