Ford V10 Engine tuning
T/H is Tow Haul mode. When engaged the torqshift transmission software changes the shiftpoints to keep the transmission in the lower gears longer before upshifts. The purpose of tow mode is to prevent boil over of the tran. oil. If you had a Ford Torqshift tran., 5 or 6 spd. and the shift pts. didn't change during acceleration when in tow mode there was a malfunction in the units electronics.
Holdmybeer, thank you for clarifying that for the other gentleman. I also want to thank everyone that weighed in on the tune package for my V-10. I just installed it this morning, and the performance improvements are tremendous! If any of you are considering doing a tune, DON'T WAIT! The tuner I got from 5 Star Tuning was recommended by a friend, and they do an excellent job. I can't wait for our next run south to see the full benefit!
T.D.L.
T.D.L.
What's meant by "tremendous" ?
When you say “T/H” mode I presume you mean Tow Mode. The only change that did for me is downshift sooner when backing off the throttle. My acceleration shifts never changed even before the upgrade.
In tow/haul mode mine holds shift points longer and downshift engine brakes stronger
Based on mine it has a little bit more power, shifting has changed to be more comfortable. When down shifting under load it does not drop 2 gears right away. It will drop one gear then if needed down to the next gear. Driving with cruise control is more comfortable on somewhat level ground, however cruse control on hills or mountains is kind of useless.
I’ve grown accustomed to the new program and can control shifting up and down hills with the throttle. Drivability is just much better.
I don’t use tow/haul much. I like coasting down hills with my foot off the throttle. (Save fuel and allows engine/transmission cooling) unless it’s a steep downgrade then I turn it on. The V10 is a low compression engine so it does help, but not much.
I'm an outlier, I travel in T/H regardless whether towing or not at a cost of .25 mpg overall. The same 5 or 6 spd torqshift transmission and cooling system powers a 26k lb. gvw f53 MH as it does an 18k lb gvw f53 MH. I just figure I'm towing a house. The long term benefit, if any, I guess is arguable but there's no downside other than the quarter mile per gallon cost. The shift pts. are further apart when getting to speed, but once there it's no different.
I also pay the minor penalty and travel in T/H most all the time.
I’m amazed that you figured the fuel mileage to a 1/4 a gal difference. You get that much change an a daily basis.
I will say my fuel use changes are much greater just based on terrain .
Keeping in haul mode all the time is a personal preference and that’s fine. I choose not to because I try and avoiding the high rv shift up and down. I kind of drive the RV like I drove Dump Trucks.
I didn't figure anything, a mini computer called an engine control module (ECM) however did.
Ok, you got one of them fancy ones. I gotta calculate with my fingers and toes. LOL. 😁
Gemini3 tells me the 5 star tune is "essential" to the 5 speed ( 5R110) 2005-2015, even more so for the 4 spd. (4R100) 1999-2004. Okay for the 6 spd., but the difference in performance won't be as pronounced. Flashing the ECU in the V8 Godzilla can potentially void powertrain warranties.
It however says MPG increases will be negligible at best, maybe 0.5 mpg, with some reporting mpg losses.
Power gains ( 25-40HP) and +40-70 lb- ft of torque, better throttle response and less of the dreaded engine screaming in climbs apparently being the major advantages.
Sounds worthwhile to me especially if you're in a 4 or 5 spd.
Take that figure as more a guideline than exact..My Ram Bighorn tells me i got 23mpg but my math says 21mpg
Another vote for 5 star. You won’t increase hp but you will have better throttle response and better control of the shift strategy. And they can send you custom tunes for your specific needs.
I can’t beat computer chess at idiot level, I think I’ll pass on a math competition.
