@Rory (Lightship Team) … would appreciate a video walk-through of the production variant of the Lightship, in particular those things that changed from the pre-production version, e.g., the new pop-up table and anything else that changed.
I’m also interested in understanding why you’re making some of those choices. E.g., driving with Trek Drive off … was that a test scenario or were you low on Tow Vehicle range and knew you’d pull into serviced camping, etc.
*The CER is the minimum Lightship SOC required to establish and operate camp (unhitching, leveling, systems bring-up, HVAC, comms). CER is not a fixed number. In boondocking scenarios, it’s a function of daily energy usage, and expected daily solar refill. In practice, CER must float upwards if daily usage exceeds solar recovery.
Great start. Once we understand these variables I don't see why it could not be integrated into the Atlas tablet and let it run real time in route.
We are going to have to have a fair amount of experience to determine a typical CER. But I suspect the weather forecast may be the most important set of variable since HVAC is going to use most of the camping battery capacity. So high and low temperatures and cloud cover will have to be considered when defining the CER.
my mental model has now shifted to ‘camp dynamics’, and I think the CER, particularly in boondocking situations is going to be critical.
But I’m eager to test daisy chaining and charge the trailer with the 240volt outlet in my bed, while the truck supercharges
@josephpRV super helpful what you put together there. Thanks!
I’m not sure the feasibility of your Rivian, but for my Cybertruck, my bed outlets work while Supercharging (DC charging in general)
In an ideal world, I’ll be able to use pull thru chargers with the ability to DC charge both the truck and trailer without unhitching.
I have a 7.2 kW outlet in the bed of my F-150 PowerBoost. When I was back at the factory last April I hooked up the Powerboost generator using a Tesla Mobile Charger to the LightShip. I did not have much time to play with it, but without changing any settings I was able to move 6 kW to the Lightship via the NACS port bringing up the LightShip SOC by a couple of percent before we declared victory. I may have been able to get up to 7.2 kW but initially it only wanted to take 6.0 kW. So I am sure you can daisy chain while charging the CyberTruck.
This was the crew watching the test. That's Ben plugging in the NACS connector to the LightShip.
The advantage that you both (@turbopilot and @Blackstone) have is the ability to refill the Lightship (at whatever charge rate) delivering a convenience (daisy chain) and safety advantage, particularly when Boondocking as the Tow vehicle can 'refuel' on demand if solar isn't enough.
I love this discussion! And the three axis theory is awesome
The reason I chose no trekdrive was that I started with 50% on the trailer and intended to host two full days of demos while boondocking overnight. With plentiful DCFC here, I figured it would be easy to boost the R1T on the way.
That said, we pulled a longer day today because there was an opportunity to film a tutorial/explainer on the auto leveling system. So, instead of going far out into the swamps, I pulled into a campground and am charging up from the pedestal. Tomorrow should be close to topped up and really have no concerns with energy on this trip because there are ample options at every campsite from here![]()
