Anyone call ITR recently?
Richpatty
Wesley Chapel, NC
Ventana 4310
400hp
2007 CR-V
Hi everyone,
I had another wire burn out in my Oasis this past week and called on Wednesday to see what to do next. Had to leave a message since no one answered. No one called back. Left another message yesterday. No answer. Left another message today. Normally they are very responsive so I am concerned …. Didn’t know if anyone had heard anything.
My problem was that the four wires that lead to the electrical elements burned through completely and smoked quite a bit. See picture. Keep in mind that I have an Oasis NE-s, which is the bigger unit. It appears to have burned through where there was a connection between the lines coming from the relay and connect to the elements. These were male/female connectors used and this is where they burned up. I will probably just cut the bad wire out and replace with wego connectors, but wanted to see if what ITR would say.
Let me know of you have heard anything.
Thanks
Rich
Damn...as posted I've had several of these and have boasted about my NEST smoke detectors that alerted me to the smoke in the basement twice, at least, now.
ITR is on the left coast, can't remember if they called me back in the past, just keep trying until they pickup. I'm curious what they have to say but I think the answer is simply get to the wires and fix them yourself as you alluded.
I think @ARD spoke with them today as she has a problem with her OASIS as well, potentially a pump fail.
Thanks. And I re-read your thread on your most recent smoke from the oasis and realized I also had the same issue with the aquastats burning up…
Does not give me much faith in these things.
No, it's very concerning that the "fire" based heater in the basement is not a safe device.
Hi everyone,
Thanks
Rich
I've spoken to them twice today. Did you call 360-993-4877?
^^The number from @ARD is the one I called a couple weeks ago and did get a person.
I tried that one yesterday…800 numbers on other days.
I will give it a try!
Thanks!
Update: Same voicemail. Will keep trying. I guess I am having bad luck.
Hi everyone,
Thanks
Rich
I talked to them last week, called,,left message..called me back with in an hour
Thanks. I called again several times on Friday (using both numbers) but did not get anyone. I guess they could be busy since it’s been so cold? Very surprising since I have always been happy with their service and response. Maybe i was just unlucky and hit them when they were busy.
Anyone, I have repaired the issue and it works again. I have NOT seen any issues with hot wires or any other issues…. It’s probably better like this than the way they had it.
Thanks
Rich
Looks great @Richpatty. Just make sure your WEGO's are rated properly for the task. I screwed that up once!
I agree! Used 20amp wegos…. Each element is about 11-12, so I should. Be good.
Had a problem with mine so called Newmar.
They didn't have the answer so forwarded me to ITR.
Got through right away unit was running again in about 20 minutes.
Thanks all. I left 3 voicemails over three days and made several calls where I didn’t leave messages…. No replies. I must be on a block list.
As I mentioned above, I have never had an issue before with their service.
I fixed it myself and it has been running fine since…. I will continue to keep an eye on it.
Thanks
Rich
Thanks
Rich
I know when I talked to them earlier this week - their phones were down due to some work across the street.
Just saying they have had some issues recently.
I filled out the form online and they did call back when phones were working, then we got dropped when they went out again. Did finally get to finish the discussion.
