Need some heat
Zman300
Oshkosh, WI
New Aire 3343
34'
Freightliner XCS
Cummins 360HP
None
Watched a few videos but none really helped.
So I need some guidance on using the Oasis in our 2018 New Aire.
I turn the Oasis on at the unit.
On the Silver Leaf panel I go to climate turn the heat on.
It shows a blue flame but the coach doesn't heat up.
What am I missing.
do you have a fan setting selected..or auto?
You should have a Burner on/off rocker switch in your control panel, mine is above the driver seat
Someone with Silverleaf will probably chime in but there should also be a setting to turn on both AC elements or diesel, or both for the Oasis as well as the furnace setting.
Fluid in the Oasis has to be above a certain temp (120 if I remember correctly) before the inside furnace fans will kick on.
Oasis keeps our Superstar warm down to about 42 outside using just the electric. Below that we need the diesel assist.
Not sure. Will check.
Don't think there is a switch in that panel.
SilverLeaf is nice.
But there is so much to learn.
Yes the SilverLeaf settings for the Oasis burner options are buried in the Climate screen and the Oasis "button" just off of mid-screen to the right. Once there you will see the settings for turning off and on the burner and the 2 AC elements.
Best,
-Mark
Best,
-Mark
Will give it a another try this week.
SilverLeaf is nice.
nice when it works...a nightmare when it doesn't...there's a reason Newmar stopped using it
Got on the phone with Oasis.
Did a few tests found a bad over temp sensor.
Put a jumper on it and the heater works.
Where is a good place for Oasis parts?
Personally I have bought the parts directly from ITR. Prices are decent and they have the parts required.
