Zman300
- Jul 7, 2025
- Oshkosh, WI
- New Aire 3343
- 34'
- Freightliner XCS
- Cummins 360HP
- None
Not sure. Will check.do you have a fan setting selected..or auto?
Don't think there is a switch in that panel.You should have a Burner on/off rocker switch in your control panel, mine is above the driver seat
SilverLeaf is nice.Someone with Silverleaf will probably chime in but there should also be a setting to turn on both AC elements or diesel, or both for the Oasis as well as the furnace setting.
Fluid in the Oasis has to be above a certain temp (120 if I remember correctly) before the inside furnace fans will kick on.
Oasis keeps our Superstar warm down to about 42 outside using just the electric. Below that we need the diesel assist.
Will give it a another try this week.Yes the SilverLeaf settings for the Oasis burner options are buried in the Climate screen and the Oasis "button" just off of mid-screen to the right. Once there you will see the settings for turning off and on the burner and the 2 AC elements.
Best,
-Mark
