Zman300
- Jul 7, 2025
- Oshkosh, WI
- New Aire 3343
- 34'
- Freightliner XCS
- Cummins 360HP
- None
Not sure. Will check.do you have a fan setting selected..or auto?
Don't think there is a switch in that panel.You should have a Burner on/off rocker switch in your control panel, mine is above the driver seat
SilverLeaf is nice.Someone with Silverleaf will probably chime in but there should also be a setting to turn on both AC elements or diesel, or both for the Oasis as well as the furnace setting.
Fluid in the Oasis has to be above a certain temp (120 if I remember correctly) before the inside furnace fans will kick on.
Oasis keeps our Superstar warm down to about 42 outside using just the electric. Below that we need the diesel assist.
Will give it a another try this week.Yes the SilverLeaf settings for the Oasis burner options are buried in the Climate screen and the Oasis "button" just off of mid-screen to the right. Once there you will see the settings for turning off and on the burner and the 2 AC elements.
Best,
-Mark
nice when it works...a nightmare when it doesn't...there's a reason Newmar stopped using itNot sure. Will check.
SilverLeaf is nice.
But there is so much to learn.
When did Newmar stop using Oasis?nice when it works...a nightmare when it doesn't...there's a reason Newmar stopped using it
I think they're talking about Silverleaf.When did Newmar stop using Oasis?
Oh ok.I think they're talking about Silverleaf.
They are returning to KIB as I understand it from the academy class this past fall.Oh ok.
What are they using now.
Personally I have bought the parts directly from ITR. Prices are decent and they have the parts required.Got on the phone with Oasis.
Did a few tests found a bad over temp sensor.
Put a jumper on it and the heater works.
Where is a good place for Oasis parts?
My bad...I was talking Silverleaf.When did Newmar stop using Oasis?
