Oasis flush
Phase one complete,
:) Camping world had it on sale for only $20,99 per gallon.View attachment 31372
Charlie, after filling the main unit, approx how many gallons did it take to fill the two heating loops? Trying to estimate how many gallons I need as my Ne-s needs nearly 14 to just fill the unit.
Thanks
Rich
Sorry...I wasn't paying too much attention to what the Oasis loops consumed. My CH50 doesn't hold as much... I had leftover fluid from 3 x 5 gal pails. You have more than I would need for my system. I didn't mind having extra to keep on hand for topping up as needed.
Gotcha. No worries. I looked up the Ch50 with the its distribution module and it takes about 8.5 gallons. How much do you think you had left over of the 15 gallons of mix?
Rich
Rich
At least three clean...maybe four.
May have been some trapped fresh water from flushing. I flushed with DI water and then blew the system out with regulated air pressure before filling the system with fresh fluid. I have zero clue if maybe some low points held water, or how much laid in the bottom of the Heating unit's tank.
Perfect. That gives me a guess of how much fluid to have on hand. If you had 3 or 4 left, that means you used 2-3 for filling the lines (or had some residual fluid left behind). I have about 17 gallons on hand…but may want another 2 or 3 more to be sure. I figure I could always return unopened gallons or keep them as they never go bad.
Thanks.
Good point
